go to shbox.com there is a description on here how to fix this. solder in resister though so problem does not come back because of loose connection.
Won't turn "on"
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
He's got it running again, he was able to repair the stock ignition cylinder-Joel
OK. It was not the cylinder I guess. It was running great while idling in the garage for about 10 minutes when it just turned off. It didn't sputter or shake. It just shut off like I turned the key off. After that, everything failed to work. No dash, wipers, etc. Went back to the original problem. Where is the main ground for all of the interior fuses?sigpic
Ambitious but Rubbish
Even in the Slomaro (Bessy), a Squeeling Tire is a Happy Tire.
Im going to stop saying anything positive at all in this thread, every time i do it quits again.-Joel
Breakthrough! I decided that going about this in a methodical manner is not working, so I did it the Dennis way. I got under the dash and started shaking wires. IT WORKED! lol The plug that goes into the ignition switch module under the dash was twitchy. A little bending and dielectric grease and no more issues. Every once in a while, the Dennis way (which is usually just the wrong way... only faster) works! Thanks for the help guys.sigpic
good ole bessie lives again!-Joel
Glad to hear it's all cleared up! The ignition switch is a pain to replace, dropping the steering column and all, so lucky that just fixing the loose wire did the trick. Now, go drive it!
1988 Chevy Camaro- 400 sbc, Ls1 rear 3.23 gears, T5. body work in progress
