Bmr strut brace, tubular lca's, bmr upper a-arms, relocated spohn adjustable toque arm, bmr weld in subframe connectors, 10 point roll cage
4th Gens's: List your suspension mods
What this guy said. I have never had a front sway bar on my car.. When I had my 18's on all 4's handled like a charm..Originally posted by SS4Matt View PostIt helps to unload the front of the car with the sway bar removed up front, also saves a little weight. Your car doesn't drive like crap with it removed IF you have a nice large rear drag bar, or an actual anti roll bar. My wolfe anti roll bar in the rear is so strong it keeps the front planted just fine for normal driving.sigpic
i dont think my car hooked bad for having stock suspension. my best 60' was 1.64 but did mid 1.7s on a regular basis even with street tires. i very rarely wheel hopped and ran straight. maybe next year i will find a reason to go adjustablesigpic
Front:
UMI upper/lower control arms
UMI K-Member
Eibach Pro's (1/2 coil trimmed)
Bilsteins
1LE front sway bar
Rear:
UMI control arms
UMI rear sway bar
UMI pan hard relocate
MWC adj pan hard
Eibach Pro's
Bilsteinssigpic
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
SLP Bilsteins all the way around, STB, Summit lowering springs in front, stock springs with heater hose mod rear, Founders LCAs, relocation brackets, adj. Panhard
- Koni Yellows
- UMI Performance Road Race Tubular K-Member
- UMI Performance Tubular Upper A-Arms
- UMI Performance Tubular Lower A-Arms
- BMR Suspension 4l80e Torque Arm Relocation Crossmember
- UMI Performance Non-Adjustable Torque Arm
- UMI Performance Strut Tower Brace
- UMI Performance Adjustable Tubular Panhard Rod
- Prothane Poly Motor Mounts
- UMI Performance Weld-on Lower Control Arm Relocation Brackets
- J&M Tubular Rear Lower Control Arms
- Z-28 Front/Rear Anti-Roll Bars
- Sam Strano Springs
- Energy Suspension ARB Polyurethane Endlinks
- Energy Suspension Torque Arm Polyurethane Bushing
- Energy Suspension Polyurethane Transmission Mount
