My 94 z28 will be under going alot of changes this winter,I will be taking alot of pictures and posting them as I go along..Plans are forged 383 stroker,Bmr tubular K member,Bmr tubular upper and lower A arms,ABS delete,Le2 Dart Pro 1 heads..I actually sold my old short block last weekend,so I actually started the build,but forgot to take pics
..I should be getting the short block back next week,I need to talk to Mike and see about getting a re-stall...Stay tuned..If this is in the wrong section,feel free to move it..
Project Rebuild
post some pics of the build! Glad that block is getting put to good use
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
you know mike did you change motor mounts aswell? i know some people have this issue when changing their motor mounts.Originally posted by my1994z28 View PostI have some pics to upload...I ran into problems with the BMR k-member...after installing it my steering shaft is now hitting the driver side header..anyone else have this problem?wishing i could drive like joe and the atm squad
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
On my BMR K-member the built-in poly mount was crooked by a couple degrees. Maybe the engine positioning has been slightly altered with your new k-member. From a fabrication standpoint I imagine it would be pretty difficult to get the engine position exactly where it was stock. From what I remember many sets of headers already require clearancing of a tube for the steering shaft as it is, I could see even a slight change in positioning with the new k-member causing a minor clearance issue.
Interior Whore
- 6380
- fred
- 1996 Camaro z28
but he has pacesetters, i completly agree with what your saying, but they are known for not having clearance issues. im more onto the motor mount idea.Originally posted by birdie2000 View PostOn my BMR K-member the built-in poly mount was crooked by a couple degrees. Maybe the engine positioning has been slightly altered with your new k-member. From a fabrication standpoint I imagine it would be pretty difficult to get the engine position exactly where it was stock. From what I remember many sets of headers already require clearancing of a tube for the steering shaft as it is, I could see even a slight change in positioning with the new k-member causing a minor clearance issue.wishing i could drive like joe and the atm squad
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Oh no, I agree with you too, it probably is motor-mount related. I'm just saying that since one of the motor mounts is built-in to the k-member (and stock clamshell/mount isn't reused), it's possible that it's BMR's fault since I've seen it happen before and it's hard to notice unless you're looking for it. Just something to check for shits and giggles.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
One fix is to loosen the bolts for the steering column inside the car push the steering wheel towards the middle of the car it (only moves very little) then tighten it down that slight movement gave us enough clearance. recheck or do this with wheels on the ground. Side note have bolt in steering coupler loose when you do this. Because of the pivot angle from inside you can get up to an 1/8" by headers. final clearance was obtained by filing the ridge off on the head of the coupling bolt.
Usually this is enough, when you are driving and on the engine torque moves engine up on drivers side and will give you more clearance.sigpic
Yeah you can get a decent amount of movement just loosening the two bolts under the dash and pushing the steering wheel towards the center of the car. You won't notice it when you're in the car driving, but it does make a difference for clearance by the headers.- Brian Meissen
