Originally posted by jderry
View Post
LT1 Cam Reconmendations
I went with Comp Pro Mags NSA 1.6 rr, but give lloyd a call, he will tell you exactly what to get.sigpic
Cam swap in the car is not a big deal I have done several on mine. Will be a little tight for changing valve springs in car but it can be done.Originally posted by jderry View PostAlright, kinda off topic, but is it generally easier to do this in car, or drop the front K?sigpicJust a slow 400 plus RWHP LT1.....428/370 NA
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
i did it without dropping the motor wasnt all that hard.wishing i could drive like joe and the atm squad
Can I do the white spring mod in the car too?
Are our lifters spring loaded? Where when I take the pushrods out, they pop up, or do they need to be removed via removing the intakessigpic
1996 Base Model
+2 cylinder mod
due to the fact you have an auto id say yes. I did it with an M6 in the car and i will NEVER attempt it again. Ive never let so much foul language fly in short time in my lifeOriginally posted by jderry View PostCan I do the white spring mod in the car too?
Interior Whore
- 6380
- fred
- 1996 Camaro z28
lmao come work on my car i make a trucker blush everytime i work on it.Originally posted by JoeliusZ28 View Postdue to the fact you have an auto id say yes. I did it with an M6 in the car and i will NEVER attempt it again. Ive never let so much foul language fly in short time in my life
Originally posted by MunsterZ28 View Post
sounds like out the hull exhaust !! sounds great'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Interior Whore
- 6380
- fred
- 1996 Camaro z28
lol thanks that was threw stock manifolds and a lm1 sounds better now threw lt's ory and a cutout. darren claims i changed cams thats how good it sounds.Originally posted by Gregs_gsxr View Postsounds like out the hull exhaust !! sounds greatwishing i could drive like joe and the atm squad
Getting the oil pan to clear the bellhousingOriginally posted by birdie2000 View Postlol, no kidding, same here. Beer helps...
What makes it so much harder on a M6?-Joel
