LT1 Cam Reconmendations
  • #46
    Originally posted by jderry View Post
    That's what I am going for, 12s but still streetable.
    I sent AI an e-mail. What 1.6 RR and shims would you guys reconmend.
    I went with Comp Pro Mags NSA 1.6 rr, but give lloyd a call, he will tell you exactly what to get.
    • #47
      Alright, kinda off topic, but is it generally easier to do this in car, or drop the front K?
      1996 Base Model
      +2 cylinder mod
      • #48
        Whats the car run now? I don't see why you could get that car into the 12's on a stock longblock.
        • #49
          13.379 is the best so far
          Usually its high 13.3s- low 13.4s
          1996 Base Model
          +2 cylinder mod
          • #50
            Cam swap in the car is not a big deal I have done several on mine. Will be a little tight for changing valve springs in car but it can be done.
            • #51
              i did it without dropping the motor wasnt all that hard.
              • #52
                Can I do the white spring mod in the car too?
                Are our lifters spring loaded? Where when I take the pushrods out, they pop up, or do they need to be removed via removing the intakes
                1996 Base Model
                +2 cylinder mod
                • #53
                  due to the fact you have an auto id say yes. I did it with an M6 in the car and i will NEVER attempt it again. Ive never let so much foul language fly in short time in my life
                  • #54
                    lmao come work on my car i make a trucker blush everytime i work on it.
                    • #55
                      Originally posted by MunsterZ28 View Post
                      i no kid, sir
                      sounds like out the hull exhaust !! sounds great
                      • #56
                        lol, no kidding, same here. Beer helps...
                        What makes it so much harder on a M6?
                        • #57
                          lol thanks that was threw stock manifolds and a lm1 sounds better now threw lt's ory and a cutout. darren claims i changed cams thats how good it sounds.
                          • #58
                            Getting the oil pan to clear the bellhousing
                            • #59
                              If you already ran a 13.3 I would leave it alone.
                              Maybe change the rear gear but if it were me I have a hard time justifing a cam swap when it already runs well.
                              • #60
                                that is because your happy being slow
