Anybody buy Ebay rotors?
  • #31
    i have these and there great but.... i noticed no difference over brand new stockers. Lt1 brakes overall = fail
    • #32
      Tested mine from 110-0 last night, it was no better than stock I'm sure, but they worked. Brake dust was blowing past me when I finally stopped
      • #33
        well I think I'm now shifting the focus of this thread less from those rotors and more toward an LS1 brake swap. What will I need for the swap besides front spindles and LS1 rotors/calipers?
        Originally posted by JasonH
        • #34
          http://www.ls1tech.com/forums/suspen...-pictures.html
          • #35
            so are the rear brakes on LT1 cars the same as the rear brakes on LS1 cars? also, will I need to redo my alignment after installing the new brakes?
            • #36
              anybody?
              • #37
                LS1 uses a completely different ebrake system so you are going to have to deal with that. I believe LT1s just mechanically lock the caliper vs LS1 actually has a very small drum setup. You are never going to overdrive the capability of the LT1 rear brakes, so imo leave well enough alone.
                If you simply throw new rotors and pads on it, no alignment needed. If you swap the spindle to Ls1 then you will need an alignment
                • #38
                  correct
                  • #39
                    yea i wouldnt bother changing the rears. but the front swap is something id like to do soon myself.
