Ls motor into a 95 z28
    why would an LQ motor be different? Its just an iron version of a 6.0 still uses cathedral port heads and everything. Reason most guys use them is because the block would be stronger making big hp on them.
    uhhh an LQ would be different cause its not an LS1
      I understand that but its not like there is a huge difference between one and an LS1 is my point. Because it has 18more ci and is iron that makes it better/cooler?Might as well just use whatever you can get your hands on for cheapest in that case.
        you arent following me.
          agreed
            An ls1 is over-played
              why do you think I got rid of mine?
                cause it was sippin somma teh coolant!
                  I don't want to do an engine swap. I want a 383 LT1 thats it. If I wanted to do a engine swap it would be off the wall. Ill swap a RN26DETT twin turbo. Rofl kidding.
                  Originally posted by Yoshi94
                    So are Chevlles and 69 Camaros over played because people put stroked small blocks in them?
                    2015 Silverado
                      no. Im am saying the whole picture. An LS1 swap is common as hell. I even like Jeff's build a lot cause its unique to being an LS2, dont see that a whole lot
                        Settle the debate. Put a LS9 in.
                          didnt the guy ask for advise not a debate
                            this is Mifbody and we jack threads like a 13 year old playing GTA
                              And the LQs aren't? No one does an LS1 swap anymore, it's always LQx. Just go with any of the LS-series and be done with it.
                                I see a ton of cars thathave the generic LS1 swap. All im saying is its very common and there are better motors out there than the LS1. You guys are reading into what I said way too much
