Originally posted by DETROITMUSCLE
View Post
Ls motor into a 95 z28
I understand that but its not like there is a huge difference between one and an LS1 is my point. Because it has 18more ci and is iron that makes it better/cooler?Might as well just use whatever you can get your hands on for cheapest in that case.Originally posted by ThreeHonks View Postuhhh an LQ would be different cause its not an LS1Doing less with more
you arent following me.Originally posted by DETROITMUSCLE View PostI understand that but its not like there is a huge difference between one and an LS1 is my point. Because it has 18more ci and is iron that makes it better/cooler?Might as well just use whatever you can get your hands on for cheapest in that case.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I don't want to do an engine swap. I want a 383 LT1 thats it. If I wanted to do a engine swap it would be off the wall. Ill swap a RN26DETT twin turbo. Rofl kidding.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
So are Chevlles and 69 Camaros over played because people put stroked small blocks in them?Originally posted by ThreeHonks View PostAn ls1 is over-played2015 Silverado
no. Im am saying the whole picture. An LS1 swap is common as hell. I even like Jeff's build a lot cause its unique to being an LS2, dont see that a whole lotOriginally posted by Boost Addict View PostSo are Chevlles and 69 Camaros over played because people put stroked small blocks in them?
Lurker
- March 13th, 2010
- 3476
- TJ
Settle the debate. Put a LS9 in.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
And the LQs aren't? No one does an LS1 swap anymore, it's always LQx. Just go with any of the LS-series and be done with it.Originally posted by ThreeHonks View PostAn ls1 is over-played- Brian Meissen
I see a ton of cars thathave the generic LS1 swap. All im saying is its very common and there are better motors out there than the LS1. You guys are reading into what I said way too muchOriginally posted by meissen View PostAnd the LQs aren't? No one does an LS1 swap anymore, it's always LQx. Just go with any of the LS-series and be done with it.
