No they dont. How could they?
N8's eBay Speed Daddy Lt1 headers install
The manifold gaskets I reffered to have all the holes that the head does. Eric L
eric, i had the same experience. My manifolds used some different bolt holes than my headers. I'm not sure why, but i take it as evidence that all LT1's were intended by God to have headers intsalled on them
The felpro gaskets have all the bolt holes that the heads have on them. And are blow proof. Double win. Eric L
Then its the manifolds that dont use all of the holes. I cant remember exactly, but i definitely noticed what brian was talknig about when i did mine.-Joel
I love how this is continuing to go on but hes already mentioned the headers came with metal gaskets that I'm sure he intends to use. gotta love mifbodyDoing less with more
gotta love slow days at work...Originally posted by DETROITMUSCLE View PostI love how this is continuing to go on but hes already mentioned the headers came with metal gaskets that I'm sure he intends to use. gotta love mifbody-Joel
The reason I bring it up is because the ones I use cost $5.00 and are notched and are a lot easier to install in tight engine compartments. And another user said they worked until he removed and replaced them. I have been using mine multiple times since 2002. Thats why I brought it up. Eric L
No eric, this is all your fault and everyone is mad at you
The stainless ones I got with my headers worked until I reused them. Also smeared them with copper RTV the first time I installed them. Surprisingly, it actually did not burn off.Originally posted by prorac1 View PostThe reason I bring it up is because the ones I use cost $5.00 and are notched and are a lot easier to install in tight engine compartments. And another user said they worked until he removed and replaced them. I have been using mine multiple times since 2002. Thats why I brought it up. Eric L
Used to own a Firebird.
been running my stock ones since I've owned the car, no leaks. LT1 gaskets must really suck compared to the mls LS gaskets.Doing less with more
How do you figure ive had no problems with my header gaskets?Originally posted by DETROITMUSCLE View Postbeen running my stock ones since I've owned the car, no leaks. LT1 gaskets must really suck compared to the mls LS gaskets.-Joel
Problem solved, Percys is the #1 best gasket i've ever used hands down
http://www.percyshp.com/store/seal-4...t/cat_437.html
