Interesting point you bring up... sounds possible to me. The articulating ones aren't that much more are they? Plus UMI had that sale... had me lookin too
Project: PBR-Built Z/28
I can't see the pic but I assume you have the poly ones, if that is the case they should "flex" more at the joint than a heim joint would. They are used to keep the sound at a minimum, the heim joint pieces seem to work better but come at the cost of being noisy, doesn't bother me at all.Doing less with more
How would a solid poly busing flex more than a heim joint? Or are you talking about the mount? I have a rubber bushing on the body end of my LCAs, but I don't think that helps much at all... the LCA is a snug enough fit to still be a problem. I am worried about noise basically not at all, race car!Originally posted by DETROITMUSCLE View PostI can't see the pic but I assume you have the poly ones, if that is the case they should "flex" more at the joint than a heim joint would. They are used to keep the sound at a minimum, the heim joint pieces seem to work better but come at the cost of being noisy, doesn't bother me at all.-Joel
the poly joint flexes under pressure where a heim joint is solid, it may swivel but once bolted up it shouldn't move. hats why mad man uses a heim joint in his torque arm design its the only way to truly have an instant center, if he used a poly bushing it would flex enough to move you IC around some on launch.
Hopefully Larry can help confirm this as its how I was understanding it.Doing less with more
I think i see what you are saying, but as I understand it the poly bushing only has room to flex in the direction of acceleration and deceleration forces. However torsionally, the control arm itself is snug enough within the body/axle that articulation would be limited even if there were no bushing or bolt connected at all.Originally posted by DETROITMUSCLE View Postthe poly joint flexes under pressure where a heim joint is solid, it may swivel but once bolted up it shouldn't move. hats why mad man uses a heim joint in his torque arm design its the only way to truly have an instant center, if he used a poly bushing it would flex enough to move you IC around some on launch.
Hopefully Larry can help confirm this as its how I was understanding it.-Joel
I agree, but I don't see the lateral movement happening either. The heim joint LCAs I have come with spacers that fit just as tight as the stock LCAs the only way mine move are to adjust length no side to side or forward to rear movement.Doing less with more
well i dont want forward or rearward movement
... I just want them to be able to twist freely, that is my concern with the BMRs I have now.
put stock on then
I don't think you want them to twist at all but then again I could be wrong.
When cornering (which i will be doing) one side of the suspension is going to compress more than the other. They need to be able to twist in that scenario. For a drag setup they wouldnt need to.Originally posted by DETROITMUSCLE View Postput stock on then
I don't think you want them to twist at all but then again I could be wrong.-Joel
right, they are stiffer laterally which would be a good thing right? I seem to remember the adjustables on jeff's car had heim joints - meaning I could grab the control arm and twist it back and forth a certain amount, and that was more than what would be necessarily for axle articulation.-Joel
they do clock slightly but I don't think thats articulation, would be interesting to mount a go pro or similar camera back there and see it all work.Doing less with more
articulation is when the angle of the axle is not identical/parrallel with the bottom of the car, so yes thats what its forOriginally posted by DETROITMUSCLE View Postthey do clock slightly but I don't think thats articulation
And I know i need a torque arm... that is all planned out already just waiting for the right deal to come along.-Joel
