Reading this thread makes me want to bring the pumpkin out of retirement to keep you in line
Project: PBR-Built Z/28
Whenever I'm ready for a tall PBR? Sounds like were in for a lot of racing this summer
Lines from our sponsor [MENTION=4187]EAA Engineering[/MENTION] are here!
Looks good Joel! gonna say those are 6an? You running AN lines from the sending unit to rails? where you running them on the car? I got my car buttoned up last night with paint and i'm going to throw the tank back in it tonight and going to reroute the lines this time since i got an x pipe and ditched the y, didn't like where i had them last time..... you running 8an feed and 6 return? and did you get that power steering alt relo bracket installed you got from me? Kill me now, i want to get my car back on the road now seeing your car almost done, just waiting on MWC to pull there heads out of there asses.
6AN on both sides routed along the driver side of the car from sender to rail. Hopefully i'll get them done today.Originally posted by dawdaw View PostLooks good Joel! gonna say those are 6an? You running AN lines from the sending unit to rails? where you running them on the car? I got my car buttoned up last night with paint and i'm going to throw the tank back in it tonight and going to reroute the lines this time since i got an x pipe and ditched the y, didn't like where i had them last time..... you running 8an feed and 6 return? and did you get that power steering alt relo bracket installed you got from me? Kill me now, i want to get my car back on the road now seeing your car almost done, just waiting on MWC to pull there heads out of there asses.
Havent done the alt relocation yet, but thats one of the things I plan on doing before spring hits if there is time. I will be adding a power steering cooler at that time also.-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I routed mine along the rocker.
The first picture is the driverside front fender well.
Third is on the back of the rear seat well.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Well id like to say i got a lot done today but i think the more accurate statement would be I just worked a lot. Also successfully destroyed my dads drop light!
Made a lot of progress though. The swaybar took a lot longer than it should have after a disaster with an end link but shes on now. I might have to do it again though, i think i need some beefier u-bolts. Here's some pics from today, the lines are all connected, i need to get them tied up... I gave myself a little too much service length
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
rear seat floor mod91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
