Originally posted by OVRKILL
View Post
Project: PBR-Built Z/28
Lol. I built it this way intentionally because I wanted the sound. I figured dual 3" would be "OVRKILL" for my power level anyway, it certainly doesnt have any trouble breathing
I would say from a search on tech that you should be fine (granted its ls based, but should still be close): http://ls1tech.com/forums/pcm-diagno...injectors.html
Originally posted by OVRKILL View PostCant speak to the injectors, but would like see an X-pipe and the choke-masters gone.
open headers for the win
and that is an h-pipe there smarty pants
Do LS cars use the same capacity injectors? I can't even remember what LT1s have stock.Originally posted by jetice View PostI would say from a search on tech that you should be fine (granted its ls based, but should still be close): http://ls1tech.com/forums/pcm-diagno...injectors.html
Oh, and I definitely tried to start the car open headers today... freakin fuel pump wouldnt fire for me one last time! Boo!-Joel
Stock for 94+ lt1 is 24#-hr. And boo is right! I couldn't imagine how loud your car would be with open headers
p.s. I thought they had 26's in them. You are right on the edge for a 24#Last edited by jetice; October 14th, 2012, 07:09 PM.
Hmm, ill have to check into that.
Also, i will 100% for sure be doing SLP springs/shocks this winter as well as new founders LCAs and installing that torque arm. I will plan on a project beer & pizza day sometime this winter. I expect it to be a completely different car in the spring
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Mathematically you are at 100% on duty cycle, and quite possibly going lean at upper RPM. 30# injectors seem to be the normal for 450 bhp NA engines.
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Thanks man, can i ask how you calculated that?Originally posted by hoogiesngrinderz View PostMathematically you are at 100% on duty cycle, and quite possibly going lean at upper RPM. 30# injectors seem to be the normal for 450 bhp NA engines.-Joel
lol...whiskey factor. Well aware of the diff in a X and an H. Meant to say wanted to see an X..........and while you're at it. Ah hell never mindOriginally posted by jetice View PostI would say from a search on tech that you should be fine (granted its ls based, but should still be close): http://ls1tech.com/forums/pcm-diagno...injectors.html
Good to hear! glad you will stepping up!Originally posted by JoeliusZ28 View PostHmm, ill have to check into that.
good start....Originally posted by JoeliusZ28 View PostThanks man, can i ask how you calculated that?
http://www.gtsparkplugs.com/InjectorSizeCalc.htmlsigpic
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
(Brake Horsepower X Brake Specific Fuel Consumption)/(Number of Injectors X Duty Cycle)
This is with the injectors flow rated at 43.5 psi. I like to see the duty cycle below .85. BSFC is typically between .45 and .50 for NA cars - .50 is normally used for the calculation
