The items I unplugged where Coolant temp sensor on the water pump, AIR pump, (I don't have a fuse in the AIR pump because old one burned up could this be causing issues?) 2 electric fans, IAT, and MAF. I pulled the AIR pump back in this morning, the coolant fans yesterday, the MAF and the IAT, and the coolant temp sensor yesterday.
EDIT:
I also noticed the RPM would sit around 1000 then would drop to 650 if I hit the gas it would go back up sit close to 1000 then drop after a bit. Vacuum leak?
Also 99% positive the plug wires are correct on the Optispark.
EDIT:
