Well I changed the coil, although I changed the coil in March when the MSD coil died. I just got back from Michigan Works gonna eat something and then change back to the AC Delco wires. I mean Ryan said he changed the Optispark not to long ago so why would it just suddenly die, if it is that. Could it be the cap and rotor on it?
Also I have all the wiring diagrams from 93 - 02.
EDIT:
I did both tests Meissen mentioned and both seemed to fail. The DC test I got maybe a 1/3 of a volt with the key on off the ICM, and when I had my mom crank it with AC I didn't even see the meter move to the 1 - 4 volts.
EDIT:
