No run. Had to tow home.
    Well the plan is to swap out to the stock AC Delco wires, probably change the fuel filter and probably spark plugs. Still no fire, gonna look at that fuel pump. Being laid off sucks.
    Originally posted by Yoshi94
      good idea. not working sucks man. i know
        Pull a plug and see if it is wet. If your getting fuel and there is weak or no spark it will leave the plugs wet. You could also check the spark with a spark tester. Just because you have voltage at the injector doesn't mean it is getting the signal it inject fuel thus the reason it will run on ether. Sounds like it may not be getting the commands to turn the injectors on and off and I know factory theft systems stop that signal. Did the LT1 Camaro's have a type of theft system on them? If I was at work I could find this out but I am not. Also check ALL grounds from the engine to the chassis and fuses.
        Jeff
        98 Camaro Z28
        07 TBSS
          I didn't even think about pulling a plug to check for fuel. Also if I replace the fuel pump wouldn't it just be easier to put in a walboro 255? Says it's a direct replacement and costs half of a oem pump.
          I guess I could try disconnecting the battery for 10 mins and see if it resets anything.
            LT1s do - your security light would be on if it was the VATS system.
            If the injectors are soaked and the car is simply flooded, you could try holding the gas pedal to the floor and then try starting the car. That will tell the PCM to "Clear flood" and will turn the fuel injectors off while it tries to crank and then it will fire up.
            If the fuel pump is only at 38-39, that does seem rather low. And the fact that it's not holding pressure to me suggests it's the fuel pump. I thought 40 was normal but I just looked and mine sits around 40-50psi.
              Would the security light come on if the key was bad? Also does the car have a remote start of any sort?
              98 Camaro Z28
              07 TBSS
                Yeah it would - if the VATS system is enabled to kill the starter for whatever the reason is - bad key, bad voltage, bad BCM, bad VATS module [depending on the year], the security light will stay on or blink or whatever.
                  Originally posted by Fox Slaughter View Post
                  The car has ran past 1/4 usually if I cruise I use a 1/4 for weight reduction haha. I hope its not the fuel pump cause I am not doing the trap door method.
                  Dont run the car below a quarter tank on the gauge. Thats less than a quarter tank anyway, and as was said you need fuel to cool the pump. Running a tank low is often what finishes off a pump thats nearing its end. My trucks pump quit on me at the gas station after i ran it to the red.
                    Thanks meissen. Upon more research I found it also disables the fuel enable signal which goes to the PCM. But like you said if the system isn't hacked it should also disables the Start circuit. But when people start installing remote starters and alarms in their cars you never know what some of those hacks could have done or not done to make it work. (not saying this is the case here) I've worked on all sides of the automotive world and have seen things that make you say WTF were they thinking.
                    Jeff
                    98 Camaro Z28
                    07 TBSS
                      So what about a Walboro 255 pump?
                        seans got one for sale
                          Because I noticed its a direct replacement and you can pick them up for under 100 bucks. Plus I plan on making some good power so why not do it now? Does it plug right into the harness?
                          So do you have to remove the rear seats and peel the carpet back and then you have access to the trap door correct?
                            So did you just cut 3 sides and bend the floor up and just push it back down or did you like tac weld it back shut.
                            Cut all 4 sides and changed the pump. I believe I put a piece of foam or something in there to keep noise down, squished that down and sheet metal screwed a piece back over. I can't remember 100%, it was like years ago now. Fold the rear seats forward and pull the carpet flap up to get access to it. And no there isn't an aftermarket alarm or remote start on it Jeff.
                              I will eventually put a alarm system on it but the remote start I will not bypass the clutch switch for that crap. I just tell my girl in the middle of winter to run out and start my car. Maybe thats why I don't have a girlfriend? Hahahaha!
                                i have a 255 for sale.. it was in my car last year only and my car only got like 200 miles put on it last year. 50 bucks if your interested
