Bypass VATS
  • Bypass VATS
    So I thought my key was bad, went and bought another key from my GM dealer. Doesnt work. Went back and he showed me the tester. Both keys work great and have the same number associated with them. After talking with the service tech guys they think that the ignition module its self has gone bad.
    How the car has started so perfectly for the last week is beyond me, it simply will not start today. I'm not going to sweat the small stuff, I paid a lower level so I expect these issues.
    To disable VATS it looks like I guy the wire going to the key, throw in a resistor with my value of ohms and that should just send the PCM the correct electrical signal without even needing the chip part of the key.
    Here is the write up I found, there are many others like it: http://vats.likeabigdog.com/
    Before I start hacking into this car, I want to think of other ideas.
    Here is what happens:
    Put car in N, put key in, turn one position and radio comes on(this confirms the key is good) turn to next part and the fuel pump primes like it does on all cars, turn it to Crank, and the SECURITY light comes on. Wait exactly three min and try it again.
    OK, what do we think.
    This car is doing the exact same thing
      Didn't watch the Vid because I've done the Bypass on my own car and it is quite simple.
      Just make sure you leave enough wire to work with and make sure all the soldered joints are solid as any loose connection may disable the car.
      Craig
      Semi Retired Street Racer
      GONE BUT NOT FORGOTEN
      NBM `98 Formula M6 HdTp
      1 of 1 Build Date 3/12/98
      - Smokey Yunick
        Did your car do what I described mine doing?
          VATS has 2 modes (that we know of) Pass/Fail which is the normal mode and a Start Default mode.
          Pass/Fail reads the keys resistence and starts the car if the proper value is found. The Start Default happens when the system detects an issue but still allows the vehicle to start (but the light may remain on). The problem is you never know which mode the car will be in at any given time.
          My Car hovered at Start Default for years but would occasionally revert back to Pass/Fail and flash the Security light when the key was turned. So I'd wait my 3 min then try again. It finally took a major turn for the worst last Summer and cycled 20+ times. So after almost an hour of trying to start it I walked home came back 2 hr's later and it fired right up. I took it back home and did the bypass. My first attempt failed because the soldered joints came loose, so that's why I said make sure it's a solid connection. Mine has actually acted up a couple times recently so I'm looking to check it and redo it if need be.
          Craig
          - Smokey Yunick
            Well I trust you and it sounds like we have the same experience. I am going to buy some resisters and give it a whirl.
            I am going to just unplug the connection first, and insert the wires into the plug and see if that works, if it does then I will make the cut.
              When you unplug the connection cut the 2 white wires that run to the lock cylinder and leave as much wire as you can. Then splice the resistors on to that connector then it's just plug and play.
              Good Luck
              And BTW there are literally thousands of F-body guys who have successfully done the Bypass so don't worry.
              Craig
              - Smokey Yunick
                im surprised this hasnt really given me any issues yet. The only time it did i was having an electrical issue that no doubt encouraged it.
                  Ah now you did it Joel
                  Start knocking on wood and crossing your fingers lol.
                  Craig
                  - Smokey Yunick
                    Heres the best way to bypass vats, lol. Do a swap to OBD1, get cheap tuning software, check box in tuning software to turn off vats. And doing a OBD1 swap is REAL easy. PM me and i can tell you all about it and hook you up with tuning software, let me know. Eric L
                      nates probably gonna do it right and go the other way to an LS1 pcm
                      But if you want to do that nate, ive got an extra OBD1 PCM foh sale.
                        Its up to him, but i think the 1500 could be spent in beter places right now. Id wait till the opti dies to do the swap. But if hes interested, i got a GOOD hookup on tuning software for him. Eric L
                          OBD2 FTMFW and I have a good hook up too, the internet. Eventually Ill buy the cable for my laptop, get a copy of the software and do a windows install so I can turn lights off my self. For now a five dollar resistor and solder should work.
                            Going to try this at lunch. Its about .11 different than my key.
                              best of luck to u
