My car hesitates to start...... Help Me Please!
    How long should the fuel pump hold pressure for?
    1996 Base Model
    +2 cylinder mod
      Well, lets just say it shouldn't just drop when you turn the key off.
      When my pump went on my IROC, it would only prime to 3 psi (no typo, a far cry from the 46 it was supposed to prime to), and when you turned the key off, it dropped instantly.
        Yoshi has been doing the same thing for the past 2 months haha. Luckly I have been holding out since then. Guess I better take a closer look. Mustangs have cursed our fuel pumps!
          Mine gets up to about 50psi, but when you turn the key off it drops to 0
          1996 Base Model
          +2 cylinder mod
            Yeah, sounds like the pump is gone.
              I had my dad talk to his friend whos a tech for gm he claims that running premium gas in it could cause this when its cold.
              I dont see how, but I am also not a GM tech.
              1996 Base Model
              +2 cylinder mod
                premium is a higher octane therefore require higher amount of heat to ignite it, therefore longer start to get enough heat for it to go.
                i however run 87 and still have the same issue, now thinking its fuel pump related, will cycle my fuel pump 2-3 times before firing the car and it doesnt seem to have any problems.
                  I dont know if thats my issue I always run premium or plus. My new tune is for premium though, I wonder if itll change anything
                  1996 Base Model
                  +2 cylinder mod
                    I HIGHLY doubt that would be the issue. I have run premium in my vehicles for the past 2 years and never had an issue.
                      yea, i absolutely dont see why that would affect your starting issue unless maybe your spark plugs are oil fouled?
                        Still thinking fuel pump. Kinda weird that it makes full pressure, though...
                          yea its feul pump 99% sure happened on my v8 changed so much shit hopping it wasnt the the feulpump.... but it was so if you decide to change feul pump dont drop the rearend then gas tank that took me 5-6 hours (rusted bolts) id reccommend the cutting the metal in your rear hatch right over the pump theres a lot of forums that say they prefered that way as apposed to the dropping everything method.
                            When I did the pump last year took me 3 hours, I broke a bunch of bolts and replaced them, I will not fix it untill it completely goes, it runs fine for now, not bad enough to drop the 200 for a pump
                            1996 Base Model
                            +2 cylinder mod
