My car hesitates to start...... Help Me Please!
  • My car hesitates to start...... Help Me Please!
    For the past few weeks, when ever I go to start my car, it cranks over, but nothing, I will let off and crank it again and it starts right up and runs fine afterwards
    I tested to make sure the pumps cycling correctly, I get 45psi at the rail.
    Some one told me to change the fuel pressure regulator, didnt do a thing, just wasted $50
    Any ideas,
    Thanks in advance
    1996 Base Model
    +2 cylinder mod
    I put this in 5th gen on accident can some one move it to 4th gen please.
    1996 Base Model
    +2 cylinder mod
      moved for ya
        3.8?
          Originally posted by Dudek View Post
          3.8?
          yepp
          1996 Base Model
          +2 cylinder mod
            Mine did everything the EXACT same, and it ended up being the fuel pump. Check pressure when you crank, mine tested fine off, but once I cranked it dropped way down.
              Alright will do after school tomarrow thanks.
              1996 Base Model
              +2 cylinder mod
                My bird was doing this too, but not all the time. then finally wouldn't start after it sat for few weeks. Long story short it was fuel pump. After I replaced it I jumpered it to battry and while holding pump in my hand pump motor would stick then hit it second time it would take off. Since replacing pump it hasn't done it again.
                  Yeah I wont be too happy, I think mine might still be under warranty
                  1996 Base Model
                  +2 cylinder mod
                    john check the voltage at the test plug on the passenger fender well. put meter set for 12V + on there have someone or yourself turn on the key should see 12v for 2-3 sec then 0 v. thats the prime cycle, then when you turn key to start you should see 12v+ again. that goes straight to pump. if you have all that, then its down to clogged filter ie low pressure, or pump. My guess is pump.
                      My car isnt holding any pressure at the rail once the car is turned off.
                      I cycle the key and it spikes at about 52psi, turn the key off and it drops to 0.
                      I also checked the battery with my dads battery tester, it shows good charge, but needs charging.
                      I have it on the charger now, doubt this has anything to do with this issue.
                      I am going out in a few to get new batteries for my MM
                      1996 Base Model
                      +2 cylinder mod
                        yup, lately my cars been doing the same and I've feared its the fuel pump since i had shit dumped in it 2 months now....
                        it doesn't all start the 2nd try either, i can get lucky and hit it the first or even worse the 3rd attempt, just haven't had time to check fuel pressures long as the cars getting me from point a to b.
                        you don't have a check engine light on for anything correct?
                          Usually if it doesn't hold pressure, your pump is shot.
                            Yup, time to replace the pump. Make sure not to run the car lower than 1/4 tank from here on out
                              I have been anal and usually dont let it get under 1/3 tank =(
                              I looked at my reciept and the site i got the pump from last year is not longer a website.
                              1996 Base Model
                              +2 cylinder mod
