it won't hurt the cats, your car will just be less emissions friendly at startup. You will probably have to have the code tuned out if it comes up, I'm not sure if it would or not.
LT1'ers - DELETE YOUR AIR PUMP!
I kept the air pump, when I put my headers on. Also got rid of the cat. And I just replaced the air pump this summer. When I found out it wasn't working. The engine was running in open loop. Since replacing the air pump the engine is in closed loop and runs smoother and the gas mileage is better. Just my two cents.Originally posted by 1qwikSS View Postso i know alot of people delete the air when they upgrade to headers and get rid of the cats....If someoneput in headers with a catted Y pipe...do they need to keep the air?
RickNever complain,Never explain.
Member Eastern Michigan Camaro Club
No impact to the environment whatsoever...the amount of carcinogens being emitted is the same.Originally posted by 1qwikSS View Postso its not harmful to your car to delete it with cats...only harmful to the environment?!!
But like Jeff said, you may throw a code because the perceived concentration is greater.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Eek, sorry to hear Jake. But thanks for bumping this thread - it's been awhile since this thread was bumped -- with most of our cars down for storage, it'd be a great time for some folks to consider deleting the air pump over the winter.- Brian Meissen
I'm not an LT, but I am absolutely !AIR and !EGR this winter. I have all the blockoff plates and gaskets ready to go.Originally posted by meissen View PostEek, sorry to hear Jake. But thanks for bumping this thread - it's been awhile since this thread was bumped -- with most of our cars down for storage, it'd be a great time for some folks to consider deleting the air pump over the winter.
Good plan - it's all useless anyway (since we're in MI and don't have emissions)- Brian Meissen
Dont let finding block off plates hold you back either, they are EASY to make on your own if you have basic tools. Just trace the gasket outline onto some 1/4 steel, cut it out, drill the bolt holes and youre done!-Joel
- December 5th, 2007
- 1321
- Scott Lenard
- 1994 Z28
- Macomb, MI
- Web Director at dieselops.com
Originally posted by JoeliusZ28 View PostDont let finding block off plates hold you back either, they are EASY to make on your own if you have basic tools. Just trace the gasket outline onto some 1/4 steel, cut it out, drill the bolt holes and youre done!
I'm running custom Joel block off plates. When I had my intake off I sealed and retightened the bolts1994 Z28 Black, M6, Hardtop, SLP Loudmouth I, GM Performance Cold-Air Intake, 96-97 SS spoiler, 17" x 9.5" Chrome Z06 Motorsports, Longtubes
Lurker- August 27th, 2008
- 452
- Anthony Z
- 1989 Trans Am GTa V8
- Muskegon, MI
- mechanic/quick lube tech
I got some from Summit - $25 shipped for all !AIR and !EGR with Kooks plates:Originally posted by JoeliusZ28 View PostDont let finding block off plates hold you back either, they are EASY to make on your own if you have basic tools. Just trace the gasket outline onto some 1/4 steel, cut it out, drill the bolt holes and youre done!
EGR Plate - KOK-9125BO ($3.24), need 1
AIR Plate - KOK-9126BO ($3.24, need 2 (listed as EGR, but it's for AIR)
EGR Plug - RNB-10230 ($2.95, need 1)
I got Felpro EGR gaskets too, all $25 shipped. Worth my time to just order them. Note, these are for LS engines, and I have NOT installed yet, so I can't guarantee fitment yet.
Making them out of scrap is free at the cost of about 30 minutes
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I had a problem with the block-off plate for my header not sealing. Can't remember where I got my kit though...
