Wouldn't hurt. Also - if you keep trying to start it up and the injectors are firing, you're likely flooding the cylinders. Try pushing the gas pedal all the way to the floor and then starting it - when the gas is all the way down the PCM turns the injectors off and tries to c lear the flood condition out.
messed aroundand moved the connections for the coil, Now i've got spark at the coil and plugs. but it still wont fire. hooked up jumper cables cause it seems to be cranking over too slow, scanmaster is not throwing any codes at all, and voltage was good, maybe its a starter
have you pressure tested the fuel pump it may still work but very weak...and you valve lash im pretty sure you could make it too tight see if air is coming out of the intake unlikely but worth a try. bad gas try some octane boost? idk just throwing some things out there....
im gonna loosen the rockers 1/4 turn and see if that helps
i doubt that'll help when i got mine rebuilt i had them clackin and all loose until i adjusted them while it was running. and it only took 7 crank overs to get the air out of the fuel line.
