check batery and starter, on my old TA when the starter was going bad it wouldnt start, id jump it and it would roll and roll and roll put a new starter on and bam fired right up
this may sound dumb but are all the plug wires in the right place? and are they all tight on the opti? and did you have the timing set off? if so did you put it back on correctly?
LT1 wont start
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
after you get starter back in before you loosen the rockers, pull a spark plug on each side, see if they are wet from gas. Recheck that you have spark, and have fuel pressure. You mentioned earlier you have new opti. You might have it out of time, it is possible to put them on wrong. The only way to tell is to pull front cover of opti off and check where rotor is.
there are 3 slots besides timing pin drive, you may have it in one of the slots instead of drive pin hole.Last edited by 98blackbeauty; August 4th, 2009, 05:21 AM.sigpic
His is a 94 which is non-vented and is gear driven instead of being driven by the camshaft dowel.
bolted everything up, went to start it, turned the key to the on position but didn't even crank it, and the wire going to the alternator started smoking really bad, and alternator got really hot. I looked at everything and the wires on the starter were touching each other. I also fried the fuse before the fuse block. I have a battery shutoff and as soon as you pull it out w the key off, the security light comes on and the shift light is constantly lit and the fuel pump doesn't come on. Also the windows are messed up when you push up they go down and vise versa. what the heck is going on with this thing.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Did you reverse the wires aswell as shorting them? You may have fried a lot of stuff. Check ALL fuses 1st. then go from there.sigpic
it your security light is lit you might of thrown the security system into effect which also will not allow the pump to turn onOriginally posted by qwicklt1ws6 View Postbolted everything up, went to start it, turned the key to the on position but didn't even crank it, and the wire going to the alternator started smoking really bad, and alternator got really hot. I looked at everything and the wires on the starter were touching each other. I also fried the fuse before the fuse block. I have a battery shutoff and as soon as you pull it out w the key off, the security light comes on and the shift light is constantly lit and the fuel pump doesn't come on. Also the windows are messed up when you push up they go down and vise versa. what the heck is going on with this thing.
