LT1 wont start
  • #31
    thats true im at a loss for words with this car
    • #32
      Looks like someones bypassing the VATS now lol.
      • #33
        all fusable links are good, we took them off individually and figured out that the one thats gray/gray is the one thats making my shift light and security light to come on as soon as the battery is conected. Also the windows go up when pushed down and vise versa even if the key is not in the ignition
        • #34
          man not going to lie but this sounds weird you might of fried your ecu and/or your ignition or you some how have some wires backwards somewhere?
          • #35
            I know man this is nuts, im sure i fried something i just cant find what. My buddies dad came over to help we snooped around everywhere looking for burnt wires, pulled the ecu, tore down under the dash i can't find anything wrong
            • #36
              man im sorry but im stumped i would just make sure everything is plugged in right and maybe try to test the ecu with something and look by your steering colum might have to tear it apart.
              • #37
                i think you have a loose electrical connection somewhere. i had this exact same thing happen to me before and it was just my accessory hub come loose somehow, not enough current could get through it.
                • #38
                  That could be a back circuit that causing window problem. sounds like something pluged in wrong, check plugs on PCM did you disconnect them during your head gasket repair? The other possiblility would be the 2 plugs on fender well, the one supplies voltage to fuel pump. Recheck all plugs on engine harness.
                  • #39
                    Where in clinton twp are you?I could stop by after my doctor appointment today..mike 586-718-3887
                    • #40
                      15 and harper area, Mike sorry i haven't called i've been at cedar point since yesterday morning, il be back today and give you a call later on
                      • #41
                        tried to call mike a couple of times but no luck, I'm terrible w wiring and having a hell of a time finding a fried wire, ripped apart the driver kick panel and by the pedals still can't find a fried wire
                        • #42
                          man i wish a lot of you guys lived closer, we have lots of tools for crap like this.
                          • #43
                            what tools are you talking about, can i rent them from autozone?
                            • #44
                              one of the tools i had in mind was a two component set. the first clips on the wire and sends a signal along that wire. the second picks up that signal.you clip the sender on a wire and go to the end of that wire with the second tool. if there is no signal, you just back trace the wire until it gets signal and you have found the area that is broken.
                              • #45
                                i still cant find any bad wires, if anybody lives in the 15 and harper area could stop by that would be greatly appreciated, i can provide gas money and food, or some brews. my number is 586 817 0195
