true duals Question?????
    Well im assuming true duals is quieter then an open y pipe?
      if anyone knows borla its just a straight pipe without a cat.
        depending on which adjusting plate you have in it.
        i would just put a different plate in and be done with it. whether or not you have a cat is nothing to do with the borla.
        Also, fyi - exhaust must exit at the rear of the vehicle to be legal. i doubt youll be hassled for it though.
        I also would not expect duals to be quieter than an open borla - even if the system does end up being quieter, now its got the road and bottom of the car to reflect off of and amplify it.
          Magnaflow + Cutout ftw.
            best of both worlds, nice and quiet for road trips, loud has heck to drown out those pesky ricemobiles
            -Derek-
              And even with the cutouts wide open it's still not that bad - I drive around town with the cutouts wide open and the only time it's bad is when you're accelerating from a stop. Once you hit 4th gear it's fine.
                OR he could get the DMH plate for the borla...
                but that would make too much sense
                  Omg, Joel just had a stroke of genius. Throw the e-cutout inplace of the usual adjustment plates (IE different size holes). Epic win. But true-duals are going to be wayyyyyy louder than a borla. Even if you throw some flowmasters 40s under there it is going to be crazy loud. It probably wouldn't be that bad if you had a stick, its very easy to keep the car quite with one. An auto on the other hand, not so much.
                    Will the plate really change the rasp of the muffler, though?
                      I need to get a cutout, not to thread Hijack but which one do you have on your car Brian?
                        DMH is the way to go, dont let anyone tell you different.
                          Or you can spend a little more and have a lifetime warranty and not have a broken cutout like the DMH ones RaceReady is the way to go if you're willing to spend a little extra for peace of mind.
                          Edit: NM, I was thinking it was DMH but I realized after it's QTP that break all the time. I love my RaceReady and will always recommend them, though, simply because of the lifetime warranty.
                            i used the hell out of my DMH for 5 years with no problems, then sold it for 2/3 what i bought it for. Dave hacker stands behind his product.
                            edit: yes, QTPs burn out all the time.
                              Summit 2.5" universal x-pipe system is a bolt in. No cutting/adding of pipes is needed. Did it to mine. Pics in sig if u want to look. I did 12" dynomax bullets. Sounds great to me. If I went with say 18" bullets it would still sound good though i bet.
                              94 Z28 Vert. A4->M6, Pro 5.0 Shifter/Short stick, Mccleod 7500rpm disc w/ Ram Alum flywheel, 3.42 gears, CAI, XE 224/230 .553/.561 lift w/ 1.65 RR's, LE Stage 3 Heads, 30lb SVO injectors, JetHot LTs, X-pipe Duals, LT4 Knock Module, Personal Tunercat PCM Tune. College, Grad school, and Med School Loans: payment countdown only $272,000 left. 8-O Install pictures
                                i guess im alone on this one thanks anyways guys.
