Lt1 Differences
  • Lt1 Differences
    so my dad was driving my car home on the free way, said the oil pressure dropped the car started smoking and he pulled over. And it would not restart, so my step mom and I had to get his F250 and car hauler and tow it home, luckily it was only about 15 min away. I get the car into the garage and the oil is nasty and black and smelled burnt, a little later i try to start the car and it starts right up, idles okay but when you touch the throttle the slightest it starts to knock, my dad and i decided that if we are to put a motor into it again it will be an lt1
    my question really is what is the difference between a caprice's lt1 and a camaros, other the the aluminum?
    they seem cheeper
    also i think i need a 96, 97 lt1 and trans didnt they switch to the 4l60e in 1996?
    1996 Base Model
    +2 cylinder mod
    i would look for a wrecked donor car, youll need a lt1 k member along with a list of other items.
      yeah, pcm wireing harness trans k memeber and the lt1 of course..
      but why put another v6 in, for what people are selling those for you can nearly get a v8
      1996 Base Model
      +2 cylinder mod
        http://detroit.craigslist.org/pts/1079882522.html
        will this work or no?
        do i want 4l60e over 4l60?
        1996 Base Model
        +2 cylinder mod
          that should work
            alright, im going to take the 3800 apart this weekend to see whats wrong with it. if its not worth repairing im going the v8 route
            1996 Base Model
            +2 cylinder mod
              that blows.
                Not a bad Idea to check vin number on engine, good way to verify if its the year seller claims. The vin is on the drivers side rear of engine block. right above oil filter. For a 1995 the 1st digit up should be an "S".
                  no lt1's are aluminum from the factory and ive never seen any aftermarket ones. the heads are but not the block. the caprices were updated last any time they changed the engine if that helps.
                  Sold!
                  www.fquick.com/lozanoa11
                  94 Grand Cherokee (sold)
                  95 Accord(for sale)
                  99 Outback (snow destroyer)
                    Caprice's will have iron heads, F-Bodys are aluminum.
                    2015 Silverado
                      yeah, thats what i ment lol
                      i was pretty sure they had iron heads, becuase thats the first thing my dads put on his impala was a set of aluminum ones,
                      1996 Base Model
                      +2 cylinder mod
                        I have a V8 LT-1 K-member if you need one.
                          Don't know if you know this, or if its relevant, but 93-94 LT1 are OBD1, 95 LT1 is OBD 1.5, 96-97 is OBD2. 93-94 are non-vented optis, and 95 and later are vented opti. If you can find a corvette LT1, it will be a 4 bolt main, therefore stronger from the get go. Also, 95 Lt1s are arguably the most powerful, cause they had a slightly higher CR. Hopefully some of that helps.
                            would i have to change the body harness then?
                            1996 Base Model
                            +2 cylinder mod
                              Your gonna have to change the harnesses regardless if going to a V-8. Your gonna need an LT1 harness with a coresponding PCM.
                              Originally Posted by 1BADAIR
