Lt1 Differences
    Originally posted by Bad_Z28 View Post
    Your gonna have to change the harnesses regardless if going to a V-8. Your gonna need an LT1 harness with a coresponding PCM.
    i heard not the full body harness just the engine harness
    1996 Base Model
    +2 cylinder mod
      Correct, everything else should work just fine!
      Originally Posted by 1BADAIR
        i finished pulling and taking the v6 apart today.
        there were 3 spun rod bearings and two that were flattened. also the crank is gouged in a few places, so im going to go get a crank kit
        i decided that im going to repair this engine for now, so i have somthing to drive, and keep looking for a project for it
        1996 Base Model
        +2 cylinder mod
          with the build!!!
            Good luck dude. I think the LT1s in the Impalas and what not have different accessory locations and what not too anyway.
              Yeah I think that will be the least expensive way to go. OBTW I just listed a thread on v6 to v8 swap so save that and you'll know what parts to collect. Good Luck!
                thanks
                when and if i find a v8 to put in it i will look them up
                1996 Base Model
                +2 cylinder mod
