Ok, I'm I having problems with a mount of some sort along the Driveline. If I am in 1st, 2nd or 3rd gear and give it a decent amount of throttle, my shifter lifts up. In first gear it will come close to lifting 1.5 inches up. I pulled my transmission mount off today cause I thought that was it for sure. Looking at it, it does have a tear on it. I tried to show it in a picture but it was pretty blurry.
^You can see right above that bolt hole a small tear. This is about 1/8 thick rubber, that appears to just cover up an opening, because on the other side, there is an opening and it doesn't appear to have material ripped off. Question I have is, it looks like this part was made to dampen some of the lateral load put on the transmission threw the opening. Is this true? Will that tear effect anything?
Another blurry picture
Also took another picture of the Torque Arm Mount(I think). Does anything look to be wrong with it? I can take more pictures if anyone needs to see more.
thanks for sharing the knowledge and the help!
