OptiFail
    you guys are liars my car never leaves marks. pics or it didn't happen lol.
      lmao ill get you a pic then. You left some GOOD ones, no one else did so it had to have been you. Looks like you were gettin kinda sideways and had to get out of it too
        Originally posted by Syn View Post
        i vote coils it'll look like a ls1 almost, you could find some ls1 coils for prolly 100 bucks with harness
        It's the same setup as an LSX car but the truck coils are a little bit stronger on the spark side
          im sure i could find this on my own, but does it come with coils or do you have to buy your own? i definitely want stronger spark because I would rate my own as weak.
            I think you need to get your own??
            If you click the LTCC link there is a place where you can e-mail Bob and ask him whatever you need
              ok ill check into it thanks
                thanks yeah the car definatly was going all over so I let off rather than run into a ditch.
                  I want to do the coil packs too. I was at LKQ the other day. They have alot of newer 3.8 v6s cars that have coil packs that look similar to the LS1 packs. I wonder if those will work. You could pick those up for basically free if they are the same design.
                  1997 Trans Am
                  www.fquick.com/transampimp
                    full throttle sells ltcc you just need the coils, Your still gona need a new opti prolly though.. http://www.fullthrottlespeed.com/itemdesc.asp?CartId={F42C3C98-6900-478D-8EE7-78B3EVEREST1F2EC9C8}&ic=050LTCC&eq=&Tp=
                      What cam are you gona go with?
                        x2 i forgot to ask you at the party
                        specs
                        The LS1 or Go Home Crew
                        ASE master certified
                          specs will be revealed when its done
                            convert it to coilpack. I changed my mind
                              I did a good ammount of reading on it last night, looks like its going to be pretty costly Its possible that just my cap and rotor are bad in my opti but replacing the entire thing isnt much more.
                              Right now i think i am going to get the barebones delteq that mounts down low, i prefer my engine bay clean. I'll buy my own coilpacks.
                              Kyle would you happen to know the part number for the GM truck coilpacks? I havent found anyone else that has used those so far but thats a fantastic idea.
                                Coilpack conversion FTMFW! and cam swap.....
