you guys are liars my car never leaves marks. pics or it didn't happen lol.
OptiFail
lmao ill get you a pic then. You left some GOOD ones, no one else did so it had to have been you. Looks like you were gettin kinda sideways and had to get out of it tooOriginally posted by DETROITMUSCLE View Postyou guys are liars my car never leaves marks. pics or it didn't happen lol.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
It's the same setup as an LSX car but the truck coils are a little bit stronger on the spark sideOriginally posted by Syn View Posti vote coils it'll look like a ls1 almost, you could find some ls1 coils for prolly 100 bucks with harness
im sure i could find this on my own, but does it come with coils or do you have to buy your own? i definitely want stronger spark because I would rate my own as weak.Last edited by JoeliusZ28; June 16th, 2008, 08:48 AM.-Joel
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
I think you need to get your own??
If you click the LTCC link there is a place where you can e-mail Bob and ask him whatever you need
ok ill check into it thanks
thanks yeah the car definatly was going all over so I let off rather than run into a ditch.Doing less with more
- March 29th, 2006
- 1080
- Eric H
- 1997, Pontiac, Trans Am
- Middleville, MI
- Chemical Tech.
I want to do the coil packs too. I was at LKQ the other day. They have alot of newer 3.8 v6s cars that have coil packs that look similar to the LS1 packs. I wonder if those will work. You could pick those up for basically free if they are the same design.
full throttle sells ltcc you just need the coils, Your still gona need a new opti prolly though.. http://www.fullthrottlespeed.com/itemdesc.asp?CartId={F42C3C98-6900-478D-8EE7-78B3EVEREST1F2EC9C8}&ic=050LTCC&eq=&Tp=Last edited by klrlt1; June 16th, 2008, 06:06 PM.
specs will be revealed when its done
I did a good ammount of reading on it last night, looks like its going to be pretty costly
Its possible that just my cap and rotor are bad in my opti but replacing the entire thing isnt much more.
Right now i think i am going to get the barebones delteq that mounts down low, i prefer my engine bay clean. I'll buy my own coilpacks.
Kyle would you happen to know the part number for the GM truck coilpacks? I havent found anyone else that has used those so far but thats a fantastic idea.-Joel
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
