Originally posted by BoostedSol
View Post
$2000 to mod - what should I do??
Mike makes a lot of good points, first off a converter is the only mod you will need at all to get into the low 13s I bet you could even pull off some high 12s wth a good DR. Make that first on your list and right behind it add a trans cooler ($60) Secondly buy some pacesetter longtubes with an off road y-pipe. Lastly get the car TUNED BY A PROFESSIONAL box tuners won't do shit and can often hurt performance. These three things should cost under 2K and make it an easy mid 12 second car. PEROIDDoing less with more
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
Yep, that's a good one. The Vinci programmer is supposed to be good too.Originally posted by 97rs4life View PostThe diablo sport predator unit is pretty good. http://gvperformance.com/store/index...&productId=232
Originally posted by c0ncEpT View PostA converter is the single best mod you can do to an A4 car IMO
All right, due to you just saying this I was on the last step to ordering the tune. I stopped...so now you have to tell me where to go to get it tuned.Originally posted by DETROITMUSCLE View PostMike makes a lot of good points, first off a converter is the only mod you will need at all to get into the low 13s I bet you could even pull off some high 12s wth a good DR. Make that first on your list and right behind it add a trans cooler ($60) Secondly buy some pacesetter longtubes with an off road y-pipe. Lastly get the car TUNED BY A PROFESSIONAL box tuners won't do shit and can often hurt performance. These three things should cost under 2K and make it an easy mid 12 second car. PEROID
Also, where can I buy a good tranny cooler??Your resident 10-cylinder owner
I agree. You can get a bolt on car like hers tuned for about $300 and yeild MUCH better gains than any hand held could ever dream of giving you.Originally posted by DETROITMUSCLE View PostLastly get the car TUNED BY A PROFESSIONAL box tuners won't do shit and can often hurt performance.
summitracing for the cooler...vender section has a few local places to get the car tuned2011 Ford Raptor SuperCrew
Don't waste your money on a hand held IMO. I would recommend Dr.Phil to tune the car as he tunes by the job not a flat rate and in your case having only a bolt on car wont really cost to much. Set up a time, drop your car off, have lunch with Jeff and I, Pick your car up in a few hours time. If he is not busy he can have it done that day I would like to think.Originally posted by BoostedSol View PostCould I use the diablo programmer to do some decent stuff and at least make some power and then when I have time start messing with it to get more power??
Website, location, phone number?? It sounds pretty good to me...I'm guessing this is out near GR?? I don't mind the drive I just have to get the exhaust and stall in first. I can do exhaust maybe but the stallOriginally posted by c0ncEpT View PostDon't waste your money on a hand held IMO. I would recommend Dr.Phil to tune the car as he tunes by the job not a flat rate and in your case having only a bolt on car wont really cost to much. Set up a time, drop your car off, have lunch with Jeff and I, Pick your car up in a few hours time. If he is not busy he can have it done that day I would like to think.
Its metro Detroit, Macomb to be exact. Jeff can shoot you some of his info as he got his car tuned over there.Originally posted by BoostedSol View PostWebsite, location, phone number?? It sounds pretty good to me...I'm guessing this is out near GR?? I don't mind the drive I just have to get the exhaust and stall in first. I can do exhaust maybe but the stall
He can put the converter in also but that will be a few more $$ of course.
http://www.thunderracing.com/catalog...mid=20&sid=116
The 24,000(first one on the list) should be sufficient.
EDIT:
http://store.summitracing.com/partde...5&autoview=sku
Same part number for a better priceLast edited by c0ncEpT; February 24th, 2008, 12:53 AM.
Okay, cool!! That's where I lived about 6 months ago for a while. My grandparents live at 14 and gratiot and I lived with them for a few months. So I'm familiar with the area. As soon as I get my car back from getting some stuff done (Originally posted by c0ncEpT View PostIts metro Detroit, Macomb to be exact. Jeff can shoot you some of his info as he got his car tuned over there.
) I can get moving on getting her stuff done. Actually I may be able to do the stuff with just rhino ramps. The exhaust portion of things...you get the headers hooked up, you attatch the y-pipe (welded or bolted?), and then you probably have to cut back part of the stock exhaust and attatch it?? As far as the stall converter goes I'm almost positive I'll have it installed. I hate tearing into that stuff, especially on a car I don't know too well. So I should only need a day to get it done, then I can come down and have it tuned on a saturday or something. I want to get it all done, and then have her drive it. That'd be awesome to give it back to her all done.
