Is Oil Killing our Cars? Important info about Motor oil
This is a sticky topic.
    glad to hear Amsoil is fine, Ive been running that for the past couple years.
      Guess everybody's just coming off snippy in this thread today, lol.
      Yes, oil does that to people....at least we aren't bombing each other yet
        Glad that i have been using Full Synthetic since I got the car back in 2002.
        Mobil 1 Extended Life Synthetic. FTW
        Thanks for the info guys, I will pass it along to family members that are still using conventional oils.
        1996 Pontiac Firebird - Blue/Green Chameleon - 3.8L V6 (231ci)
        Totaled & Declared Dead: 08/07/2001 - Rebuilt & Reborn: 08/21/2002
          Good info and it seems to be accepted as fact now a days. I am a firm believer that moble1 is what killed my flat tappet cam at only 6-7K miles. Oil properties sem to be changing quite rapidly over the last few years. Valvoline is on record saying that some of the oils produced now (by them) will kill some older engines in a very short period of time.
          I have also heard rumor that Mobile1 is not the oil it used to be.....ie, not fully synthetic.
          Makes a guy wanna switch to a more expensive oil like RP or Amsoil.
            I guess you have mobil 1 to thank for finally getting you motivated to do that LS1 swap eh james?
            2011 Cadillac CTS-V sedan black raven 6spd
              Don't think I'll be using M1 in the LS1!
                LMAO
                1996 CAMARO Z\28 M6
                  Ol Time Rock N' Roller
                  ok, I read ALL of this thread, I am all confused. There seems to be conytidicting statements. One said mobil 1 is good, one said it is bad...
                  bottom line, please tell me what each of my rides should use...
                  El Camino has 1995 GM Crate 350/300 :
                  1985 IROC 305 TPI :
                  1998 LS1 :
                  2001 Monte Carlo 3800 V-6 :
                  Thank you in advance
                  "OL Time Rock n' Roller on Board "
                    Dennis the only one you really need to be concerned about is the IROC cause it has a flat tappet cam. The rest of your cars have roller cams and can get by on today's modern oil. The IROC I would use Royal Purple, Amsoil or the diesel oils mentioned in the article.
                      good find have to keep that in mind and spread the word
                      00 ws6 vert a4 ( mods in garage )
                      87 fullsize bronco ( 35 inch mud terrains )
                      85 iroc ( lt1 and 6 speed )
                      honda 450r
                      honda 400ex gf's
                        Rotella isn't that good anymore. They changed the formula at the beginning of the year.
                        If you do have a flat tappet (like myself)...you can just add GM EOS (Engine Oil Supplement)...and that will add zinc.
                        Holley 650cfm Double Pumper
                        Edelbrock Performer-Plus Cam
                          Moved to the Technical & Informative Article section.
                            Keep in mind also Dennis and for any of you other late 70's to mid 80's flat tappet cam 305 engine owners that those 305's are notorious for having soft alloy cams as well. So this is increasingly important to run something like RP or AMSoil as your cams are prone to wearing out faster too. I've seen more than a couple flat tappet 305's with cam lobes so worn that they almost weren't opening the valves at all.
                              what james said. BUt I think your El Camino is going to fall in this same catagory. I don't beleive the 95 350/300 motor was roller. I'm pretty sure it uses a flat tappet cam also. That being said I would take the above oils just to be safe.
                                Originally posted by WMCC Gary View Post
                                what james said. But I think your El Camino is going to fall in this same category. I don't believe the 95 350/300 motor was roller. I'm pretty sure it uses a flat tappet cam also. That being said I would take the above oils just to be safe.
                                Agreed.
