Tackled the driver-side valve cover gasket today.
Cleaned off the valve cover some and vacuumed around the flanges to make sure no debris would fall in while trying to maneuver the thing off.
Looked nice and clean underneath.
Underside of the valve cover, cork gasket still "attached".
Gasket removed - the lower 1/3 of the gasket was pretty noticeably not attached as well to the valve cover as the rest of the gasket, and more oily. Also cleaned up the valve cover of all the grime that was on it before.
Valve cover back on. The gasket set came with spreaders
I now have one shiny and one grimy valve cover.
Back together - the clean valve cover really pops, makes the engine bay seem a little cleaner. Also wiped off some of the grime on the AC compressor and the dust/dirt on the inner fenders, fan shroud, etc.
Got it all back together and fired it up - and still seeing smoke. Looking closer, it seems to be coming from farther down - near where the exhaust bolts up to the manifold. Not sure if it's dripping down there or what, but changing the gasket didn't seem to do shit. Maybe there is residual left from before, I don't know.
That being one issue, the other is the carb, and where it likes to idle - namely about 2-3k rpm.
Long story short, talking with Craig (@9T8W66) on the phone today, he was leaning towards the distributor advance kicking in and causing the idle to increase that far all by itself.
I disconnected the 4-wire connector, disabling the advance, and the car's idle was about flawless - sitting at 1k and dropping down to 750 once it warmed up - which is pretty clearly how it is supposed to operate.
So, this begs the question of why is the distributor forcing it to idle so god damn high. Even when it would idle more "normally", it would still be at about 1500 rpm. Any ideas?
