Had to change a small amount to my previous routing of the lower cable, and figure out what the best way was to route the upper cable down, but it is connected now. I also popped under the engine to address the plug wire situation and it turns out the three-wire separator mounted to the block was there, just covered in shit, so I didn't see it before. Was able to pop a couple wires there, and playing with them, I think even if the one on the oil filter rotates, the point it may naturally gravitate too will still be off the exhaust.
So the car is back down on the ground - just need to reinstall that trim plate at the front of the carpet inside to cover the hole/firewall up (I was far too disgustingly filthy to be inside the car, which is clean - and was being eaten to death by mosquitoes, because it was nearly dark again when I started...
). Planning to do that tomorrow, hopefully when it is light out, then I just need to reconnect the battery, and it'll be time for a test drive.
I still need to coat the bottom of the ICM with di-electric, but I think that can wait until after dyno day.
). Planning to do that tomorrow, hopefully when it is light out, then I just need to reconnect the battery, and it'll be time for a test drive. I still need to coat the bottom of the ICM with di-electric, but I think that can wait until after dyno day.
