tanks easy like darren said, jack the carp up, drop the panhard and brace if you can drop the tank strap and lossen the filler neck and wiggle it out, you may not even have to pull it out all the way just drop it down enough to access the pump.
1987 Camaro "The White Knight"
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
Post Whore
- 3000
- Tyler Porter
- student
how much did you pick up the bird for?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
you should take some pics of the bird and post them on here.. maybe you can make some money back if people want to buy any parts from it."Project Shadowfax" <- Clicky Clicky
Post Whore
- 3000
- Tyler Porter
- student
If the shells clean i might buy the whole roller91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
I find it easier to remove the axle too, gives you more room to "twist" the tank for the filler neck to come out easier.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
how is the underside ie floor pans, looks like its been sitting in that spot for some time.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
