Thanks guys.
Nate's 1998 Z28 Project
I'll hand it to you, that sounds great! Unfortunately cats would ruin the sound on my car though.-Joel
Given my current exhaust setup it just had to be done, your car is perfect the way it is.
It is a bummer that the air conditioning pulley is making tons of noise now, going to need a new condenser. This car sitting for so long just caused so many more problems than I ever intended on. O well.1998 Chevrolet Camaro Z28 - 6 Speed
Great transformation Nate!- Brian Meissen
Anyone have any info or diagrams on the vacuum system for this car?
Randomly it will just idle really high. Last night it went to new levels - 3k. Yes, a 3k idle while moving. Come to a stop and it mellows down.
I pulled into a gas station and turned it off, after I restarted it the 3k idle issue was gone but it just wasn't running good. Seems more and more evident that I have a vacuum leak some place, just can't find it. d1998 Chevrolet Camaro Z28 - 6 Speed
Originally posted by nascarnate326 View PostAnyone have any info or diagrams on the vacuum system for this car?
did you ever get the issue in the tune taken care of that was making it do this too?
Anyones that rode in the car doesnt think its the tune. I don't either, its got to be a vacuum leak.Originally posted by kammi10 View Postdid you ever get the issue in the tune taken care of that was making it do this too?
Cant take it to a tuner because its got an issue and its been made pretty clear not to take junk to Phil.1998 Chevrolet Camaro Z28 - 6 Speed
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
I don't have a diagram but check:Originally posted by nascarnate326 View PostAnyone have any info or diagrams on the vacuum system for this car?
TB, front of Intake manifold, Rear of Intake manifold at brake booster, HVAC port, and MAP sensor. PCV ports on valve covers, grommet in back right of valve cover. Check PCV lines for a crack or one collapsing on you.sigpic
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Your tune looks to be off just by the numbers on the scanner. With air temp above -10 degrees, the system should be in closed loop when coolant temp hits 94°F (O2S11 and O2S12 should swing and STFT should change) and LTFT should kick in around 149°F. I can tell that your open loop is running lean. Timing looks like it has been adjusted for the cam. I bet RAFPN are a little high and throttle cracker needs reduced or get zeroed out, assuming there are no vacuum leaks.
Very common leak area the y connector in the PCV system right behind the intake manifold.
I can send a message to Darius and see if I can borrow EFIlive for a little while, might be able to get the street manners a bit better. I also have a Zeitronix ZT-2 that integrates WB02 with EFIlive for datalogging, great for VE and MAF tuning.
