Awesome! will probably be doing the exact same thing this summer with my son. he wanted a firebird but i think he will use the truck more with his "lawn service". hes a workaholic even at 14. ill definately be watching and taking notes
H3 oil pan was delivered. It was $150 new with the dipstick, pickup, baffle, pan gasket, and all the bolts. This pan is used to eliminate having to notch the frame to clear the stock full size truck pan.
yes sir. and i already have a set of 6.0 pistons and rod with arp rod bolts, only 22 miles from my last build. i have brand new rod bearings, just need main bearings and to hone it and replace the cam bearings. $200 and the short block is back together. $300 with head gaskets. but i need to finish the S10 before anything else
Not that I know of. I did one recently for a few fellas in the Flint area, but I do not think that either was a 51 Chevy. Those are my two most recent ones.
I still have to order/pick up the stall converter. I also have to paint the block. I was thinking of going with sbc orange. Or do you think I should do standard 5.3 black? What do you guys/ladies suggest? The truck will be a shade of burgundy when I get it sprayed over. Here are some visual aids!
