87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
  • #91
    cant wait to see this
    • #92
      Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
      Originally posted by masterfab View Post
      I know there a lot of question of which shift to use with the 4l80E transmission. I can tell you that's the stealth pro ratchet works perfect with the trans. And retains the factory prndl switch. You have to use a additional parts kit from B&M part # 75498.
      I know some also know this works but the are a lot that dont.
      Future video of operation. (I'm just trying to take the guess work out for some people)
      Im doing the 4L80e also. mine still needs to be gone through. some updates and new steels, frictions, and sprag.
      If some other things come through, maybe even a jakes trans brake
      - - 5.3/4L80e/T7875 - -
      - Huron Speed Turbo Kit -
      1998 Formula
      • #93
        that will be upgrade for my trans at a later date. good plans man
        • #94
          screwd up video posted
          • #95
            I've been known to do a few good photoshops Find me a good angle and I'll see what I can do, white cars work best
            Will any of these work
            • #96
              The first and last would. Do you have any hi-res photos?
              • #97
                I can look more. I found these on the net and there the only ones I could get permission to use. I beleive the last one is hi res. but the top one is a exact match to my car.
                • #98
                  Just some I found around...I could also help with a photoshop
                  Or are you looking for a two tone like this riviera
                  • #99
                    I like the 2 bottom styles rolo. They are almost what I'm looking for.
                    • Did the motor mounts show up?
                      • Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
                        I just found them yes. Thank you so much
                          Pcm has been tuned and its back in my possession.
                          Tune is as fallowed:
                          2.5 bar speed density
                          All emissions delete.
                          Rear o2 delete
                          4l80E trans
                          E-fans
                          80# injectors (ball park till dyno tune)
                          Now I'm waiting on:
                          Intercooler piping
                          Egr block-off
                          Some silcone transitions.
                          Wiring harness.
                          V-band clamps
                          Vacume manifold
                          • glad you picked it up and made it home...how was the "snow squall" back towards home
                              Update.
                              This weekend the tear down begins. Out with the v-6 and time for mock-up. It shouldn't take long as I have a lot of research and all the parts needed, minus some small odds and ends.
                              • Glad to hear. Looks like you're ready to rock!
