87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
  • #61
    Re: 87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
    Originally posted by masterfab View Post
    G-force 4l80E crossmember that summit mess'd up on, it was suppost to be a summit brand.
    3 position engine mount plates.
    Congrats on the build. Just a couple points from a guy that has several LS swaps under his belt.
    1) You will want to put the clamshells as far forward as you can on the mount brackets shown above. You will also have to slot the holes for the 7/16" bolts that hold the clamshells to the frame mount. Those adapter brackets move the holes out board, and either you slot them or preload the hell out of the rubber mounts to get it to fit.
    If you want to try a set of mounts I have designed that eliminates the bracket and stock clamshell PM me, I'm looking to test fit them on a Gbody. My setup should let you keep the truck accessory drive generator position. They put the back of the block at the same place as the original SBC would have fit in a g-body and have adjustment to move the motor an additional 3/8" back if you want to.
    2) I strongly don't recommend the Musclecar oil pan. The sump will hang waaaay below the engine crossmember and is very vunerable to getting taken out on a hard bump. An f-body oilpan or Holley pan are the best solutions. Everything else either hangs too low or puts the motor in a crappy location.
    Sent from my DROID BIONIC using Tapatalk 2
    • #62
      lol I will post it up tomorrow. I promise
      im holding you to it...you know we like pics at this joint!
      • #63
        Even more parts came today. its just about ready. Now I'm just waiting on the harness.
        My parts pile
        • #64
          Wish my parts CORNER was that big
          • #65
            And then as promissed.
            • #66
              fixed, better then new.
              • #67
                Me to I just wished everyone shipped as fast as summit. lol
                I know right! I usually get my items the following day.
                • #68
                  Summit doesnt play games, plus its nice that they are pretty close to us.
                  • #69
                    You where a big help. I would rather give a local sponsor from the forum money than summit as long as the price is fair.
                    Hey guys what after market shifters work with a 4l80E trans.
                    I bought a shifter from this site to use with my 4l80e http://www.precisionperformance.com/ Works good. You can leave it in auto or bang through the gears if ya want
                    67 Coupe Corn fed 502BBC 4L80E 371WHP/367FT lbs torque
                    70 Pontiac Lemans Vert, GTO clone, 427BBC and 7000R4
                    • #70
                      here is something to get that fire under your ass lol
                      • #71
                        I wanna see these parts working on that car, not sitting in a living room!!!!
                        • #72
                          Soon buddy. I will have enough to get started. the guys garage I was planning on using is still full or I would have started stripping the car of its old engine/trans/and exhaust.
                          • #73
                            Thanks Greg that's a nice video. start getting you paint guns ready.
                            • #74
                              Im thinking two-tone bro....do it !
                              • #75
                                Show me. lol. Photoshop.
                                Anyone one on the forum good with Photoshop. I'm looking to set this car up with 2 tone black and silver. Use your imagination!!!
