87 Buick Regal Single 76mm turbo 5.3l/4l80E budget build
This topic is closed.
  • LITTLE NATE
    • Working on cleaning up the engine bay.
      Sent from my HTC6435LVW using Tapatalk 2
      • Calling it a night. Final picture. One more coat to go.
        • Looks like it's cleaning up real nice. I hope you can get a killer paint job.
          • rattle can Ken? doesnt look bad at all.
            • Originally posted by Gregs_gsxr View Post
              Believe it or not. I used summit chassis black on the fire wall and core support. And flat black which was high temp grill paint for the plastic fenders and heater box ( closest match I could font to factory plastic) then kbs rust blast on the frame. ( same as pot-15).
              • totally forgot about grill paint for high temp areas
                • Originally posted by masterfab View Post
                  video update. the video is still up loading but will be available as soon as the upload is done.
                  thats awesome keep the updates coming!
                  • video update 14
                    • Can't wait to see this thing moving under it's own power! Keep up the great work, Ken.
                      • Originally posted by Sleeper View Post
                        All it needs is a drive shaft and the rear axle swap. Woohooo. Without the boost tube hooked up it spools pretty quick. I used a BS drive sift for a test drive.
                        • Well I had a buddy over today that helped me get some stuff done. New drive shaft is in and the cooling system is done. New injectors are in.
                          But in the end I have a huge problem. The clutch is welded to the drum and is always in 2nd gear, even when its in park or neutral. It can be shifted manually threw hp tuners. but has no reverse. Always in 2nd.
                          So with being laid off and sick this project will be on hold till next year. Sucks all I wanted was to cruise on the bad days. But s%#t happens right. Yall have a good one.
                          • Ken - not being familiar with what's wrong with it, how hard is it to fix? Does it need a new clutch? New clutch and trans? Is it something that we could help you out with? Seems like all the work you do for the guys here on the site, the least we could do is help you get this sucker cruise worthy!
                              It needs a full rebuild. I thankyou so much for your generous thaught. but I'm not even sure I could get the trans out of the thing in my condition. And I'm not sure if I could except it without feeling guilty. I did get to drive it around the apartment today with is trying to push threw the brakes. It felt really good. I do what I do to help people that have the passion for hot rodding. I love every minute of the help Iv givin. And will continue.
                              To be honest I beniefit a lot from these jobs. I get to meet new friends. And get a chance to pass the knowledge down the ladder. I love what I do. Absolutely love it. And yall on this site are just amazing!!!!
                              • Is the 4L80E like the 4L60E when it comes to valve body bolts? I had all but ONE off, no reverse and very hit/miss shifting. I could hit all manually with EFIlive controlling the trans.
