1992 Camaro- Road Racing on a budget
  • #46
    You wanted to keep the windows till a hammer met one of them.... 4 times...
    lol
    Sent from my iPhone 5 using Tapatalk
    • #47
      Impressive. So is this going to be like driving in a gutted tin can when you're done?
      • #48
        that and itll be rattly, loud, and exhaust fumey.
        00 Tahoe Z71........Stock
        • #49
          Thanks. Yes it is going to be a 2800-3000 lb tin can. If I remove enough weight, I will get the impression that the 305 is quick.
          • #50
            Don't knock the 305 too bad I have a LT1 cam you can have for free, not the best looking piece though
            • #51
              I also have an LT1 cam i can donate
              • #52
                When I install an aluminum intake manifold I will have to decide if I will install a different cam or not.
                I need to removed more weight from the nose to obtain a better weight distribution.
                I have been thinking about cutting out the trans tunnel and moving the engine/trans back 2-3 inches, but its a lot of work. It would require rerouting front brake lines, shorter driveshaft and torque arm, transmission crossmember support, and relocating the tunnel. It would probably be more beneficial to have a lighter engine which would lower the overall weight and give it a better weight distribution at the same time.
                • #53
                  Ill take the weight of that impact bar off your hands
                  • #54
                    Crash absorbing devices are being retained incase I happen to shorten the overall length of the car.
                    • #55
                      I am not going this extreme! I found this article when I was researching weight distribution.
                      http://www.modified.com/features/020...tance_program/
                      • #56
                        Manual steering. Hydroboost brake setup would save wieght
                        • #57
                          refer to the title of the thread, Road racing on a Budget! I think he would want power steering for that and hydro boost brake system would break the budget!
                          • #58
                            Hydroboost systems aren't that expensive if you know where to look.
                            But with that said...
                            Hydroboost systems run off the power steering pump. Almost zero weight savings.
                            • #59
                              Zero qieght saving but better brakes for racing. Also get a Cherokee shaft. Lots lighter than the ragjoin and eliminates wheel play amd such. You could try swapping in a rack and pinion idk if it's any lighter.
                              • #60
                                Meh, only if you have a huge cam and vacuum starve the booster. I'd run a vacuum pump before I switched to a hydroboost setup, and I'd switch to a manual brake setup before either of those.
                                Seeing that Brian is running a stock 305, don't mess with it. Upgrade to a LS1 brake setup for dirt cheap, run nice pads/rotors and some good fluid.
