[Restoration]
79z28 436sbc/4speed,cobalt blue metallic.
hello all i purchased this 1979 z28 about 3 months ago,been restoring it,just got my engine built and dynod,made 630 hp,680 ft.lbs. of torque.i will be posting pictures each day,to try to get to where im at on my c ar now.this is how she looked the day i picked it up.
By bad436z28
By bad436z28
By bad436z28
the first thing i did when i got it home was start working on my front bumper cover it was the worst spot on the car,and boy did that take alot of work to bring it back like new,first i sanded it all down with 220 grit paper,then i applied poly flex filler to all the bad spots then i sanded them all down boy that was a job.
By bad436z28
By bad436z28
By bad436z28
By bad436z28
By bad436z28
now im to the point where i sanded down all the poly flex filler,and final sanding with 400 grit,before i lay down my 2k primer.
By bad436z28
By bad436z28
By bad436z28
wanted to show you all my 87 irocz that i restored,was a 1000 dollar junker completely re done everything,and painted it myself,has a 406 solid roller engine in it making about 500 hp.
By bad436z28
so then i was ready to lay down my first 2 coats of primer before blocking it,as i realized it needeed more work done on it.
By bad436z28
By bad436z28
By bad436z28
By bad436z28
now im to the point where im putting the finishing touches on the cover before i lay the final coats of primer down.this bumper cover took me about a week to finish but was well worth it in the end.
By bad436z28
By bad436z28
By bad436z28
By bad436z28
