We'll I just started the car and the noise disappeared for the mean time. Still going to pull the covers and post up some pics after I pick up Antonio from school
Project Panther
I would recommend checking both sides if you haven't already, hard to tell from those pics. If thats not the case its possible you developed a intermittent lifter tick.Doing less with more
all comments above are very true. you may have a lifter going bad and loosing prime at higher rpms, sometimes when that happens it take a mintes to gin it prime back. heat plays a roll in the noise factor when this happens. as heat exspands the metal in the lifter. making the seal alittle looser in the lifter.
Project Panther
Buttoned the passenger side and driver side all back up and let it idle for 8 min before driving down the road.
The little knock was there a little while after idling. But was not near as loud as the one in the video. Drove it down the road and the knock continued very faint. Again increased with RPM, but only took it up to 14 mph
if it doesn't burn oil or get louder, turn up the radio and don't worry about it.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
14/05/07/2a8u9u2e.jpg[/IMG]
