Project Panther
  • Re: Project Panther- Sniper Performance build
    Thanks guy
    • One thing thats always bugged me is how the hood is lined up with the front end. The corners of it where it almost meets the windshield sits high.
      How would I go about fixing this?
      • do you have the adjustment screws behind the hinges there near the windshield?
        • I honestly have no idea. Will have to check in a bit.
            He dose. I was so focused on the work I was doing I did notice the hood alignment or I would have adjusted it for yah. next time I'm in out your way I will stop by and fix ya up rolo.
            • Its rather easy to do Rolo, just play with those screws there are some in the front and back and that will help adjust and line up the hood.
              • Gauges look great!
                • I have some hi temp paint. Thinking about pulling the valve covers off and painting them black. Cant afford powder yet. Probably ditch my fuel rail covers.
                  • Psh Darren is a cheap whore when it comes to powder coating.
                    Also for the hood I was just thinking BFH.
                    Originally posted by Yoshi94
                    • Originally posted by BP_Z28 View Post
                      Black? I will do em cheap, I have lots of semi gloss black in stock... some high glass, satin black, and some hybrid mix of a mirror black as well...
                      • Well shoot me a price that way I know when the time comes. I'd like a gloss black.
                          Trans cooler installed. Going to rock this one until I buy a bigger one.
                          Dope style. Drilled hole to route hose and to fasten brackets. Fits like a glove
                          Pic shows a test fit but you get the idea.
                          Sent from my DROID4 using Tapatalk 2 because Apple sucks
                            Passenger sidecutout decided to fail on me.
                            Would not open/close, but driver side worked great. Thought it might of been a loose connection of a kink in wiring.
                            followed the wires and didnt see anything. so i disconnected wire from passenger and connected it to the driver side to see if it would open and close it..open and close the driver side perfectly find so then that would mean my motor for cutout i
                            Time to get ahold of DMH, or is there a method I could do to clean it or something?
                            • Looking good Rolo! Just getting caught up on this thread..
                                Here is the culprit..I though my cutouts came with a block off plate just in case, gonna have to dig up the picture from coloradospeed.
                                When I get this thing on the road, I do not want to drive with one side open one side closed. So in the vent I do not have a block off plate or was not supplied them, what would be the best way to getting or making one? Sheet metal?
