He dose. I was so focused on the work I was doing I did notice the hood alignment or I would have adjusted it for yah. next time I'm in out your way I will stop by and fix ya up rolo.
I have some hi temp paint. Thinking about pulling the valve covers off and painting them black. Cant afford powder yet. Probably ditch my fuel rail covers.
Black? I will do em cheap, I have lots of semi gloss black in stock... some high glass, satin black, and some hybrid mix of a mirror black as well...
Would not open/close, but driver side worked great. Thought it might of been a loose connection of a kink in wiring.
followed the wires and didnt see anything. so i disconnected wire from passenger and connected it to the driver side to see if it would open and close it..open and close the driver side perfectly find so then that would mean my motor for cutout i
Time to get ahold of DMH, or is there a method I could do to clean it or something?
Sent from my DROID4 using Tapatalk 2 because Apple sucks
Here is the culprit..I though my cutouts came with a block off plate just in case, gonna have to dig up the picture from coloradospeed.
When I get this thing on the road, I do not want to drive with one side open one side closed. So in the vent I do not have a block off plate or was not supplied them, what would be the best way to getting or making one? Sheet metal?
