Since I broke the T56 last time out at the track - I took it down to RPM for a level 4 rebuild + bronze pads.
Decided while it was out that a Quicktime bellhousing would be worth while, hey I like my feet!
Also found the splines on the slip yoke were twisted - causing the suspension to bind and unload at the launch. I picked up a Strange chrome-moly piece to replace it.
Pulled the clutch tonight and mic'd the pads - came out .305, which turns out to be the stock thickness for the clutch. Not bad for 2500 miles and over 100 passes in the 1/4!
