Alrighty, car is back up and running.. So time to get the other shit done so I can drive the damn thing sometime before I die.. I re-did my ground wire in the spare tire area.. I now have 12.5 volts and 5.03 amps everywhere I checked through out the car(engine off).. Not starting the car again until everything is done and she's ready for a run up the road.. Time to tackle the nitrous wiring.. Can't tomorrow, hopefully Wednesday I can get out there for a couple hours...
And so it begins part II
why wouldn't you start it again periodically. It would help you figure out where something is wrong if there is a problem.
2000 Z28 - Cammed/Stalled/Intake - Collision With a Tree Mod - Totaled
2005 Grand Prix GXP - Sold
2000 SS - Sold
2011 Ford Taurus limited - Time for a practical car for a bit
Everything works.. No need to start it.. Just need to rewire the nitrous and install the wideband.. I don't want to run it much til I get it tuned... Running 8 lb smaller injectors now..Originally posted by Dewman View Postwhy wouldn't you start it again periodically. It would help you figure out where something is wrong if there is a problem.sigpic
yeah mines sitting now too until the tune. will only start it to get it on and off the trailer. unless i get the waterpump first then i will need to start it to make sure it isnt leaking, but i dont think thats gonna happensigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
Well, went out and started seriously looking at the nitrous wiring and how to re-wire it.. I was hoping I could splice in some new wires and just clean up what is there, no ****ing way.. There are wires(which should be 1 solid wire) with several splices in them. From what I can tell, they just spliced together pieces of wire laying around the shop to make a 4 foot wire.. What a joke, luckily I still have the install instructions and wiring diagrams..sigpic
Gonna do it myself... I have the diagrams that came with the kit... It actually isn't too hard... Just a little time consuming.. Hard part is going to be gutting their mess and not screwing something else up that they tapped into..Originally posted by Formula Z View Postdamn dude good luck with that. have you priced any other speed shops to redo it or will you press on?sigpic
78 MM plate kit, All I have to rewire is the basic kit, window switch stuff looks fine... So, Noids, fpss, WOT, purge and heater....Originally posted by 1BADAIR View Postwhat stuff is in your kit?sigpic
