There is a guy that used to work at Katech who is attempting to re manufacture these.
This will come directly from Kinsler.... It will still require a small adapter plate for the heads, but this is the new direction. That is until the next problem arises....
how is that less complicated? nobody has even made a filter for that setup yet I don't believe.
Going to talk with them about it....and compared to the mess I would have had on my hands prior to this, filters is the least of my worries. Probably stick with the what you see below for now....
I have always loved those intake setups.
I know you said that with the huge single throttle body that it would be a paint to tune for the street b/c it was basically idle or WOT, so are they going to try like a progressive throttle set-up with these?
thats not correct at all, you can't over TB a car like you can over carb it. His issue was the tuning required to convert it to an electronic TB.
Sweet, not digging the CF though.... Is that the only way it comes? I mean the intake alone looks cool in CF, but with the valve covers it's too much for me... I forget, what do you have for covers?
The inlet horns come CF. Valve covers....you may not believe this....are custom, shocked? Come to find out that NO ONE makes a valve cover to fit these heads and clear the rockers.
