Whats a helicoil? lol
Purple People Eater!!
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
So i think i may have found a cam but want some opinions? Its a billet core cam from Lloyd Elliot. Specs are 223/230 .565/.565 109 LSA. It has less than an hour of run time on it. And its $200 shipped? But i am also looking into buying a cc305? What do you guys think is a better idea?1999 z28 Bright Blue Metallic 1 of 10
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
thats a big cam and you would have to run stock lifters. with 1.6 rockers you would increase lift to .595/.595 and gm says max lift on stock pistons is .585. just saying. so a stock top end with a cam that big you may end up floating a valve then blamo lolOriginally posted by Purple94Z28 View PostSo i think i may have found a cam but want some opinions? Its a billet core cam from Lloyd Elliot. Specs are 223/230 .565/.565 109 LSA. It has less than an hour of run time on it. And its $200 shipped? But i am also looking into buying a cc305? What do you guys think is a better idea?wishing i could drive like joe and the atm squad
that cam looks very mild to me, why would you be limited to that lift on stock pistons? You would obviously need new springs so why not upgrade the lifters s well. I'm not quite sure what you mean by your statement Fred.Doing less with more
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Yea jeff i plan on upgrading the valve train and putting new bearings and seals throughout the whole motor.
- Patriot Performance valve spring kit - $275 -
- Hardened pushrods - Searching -
- Comp Cams pro Magnum Rocker - $285.95 -
- Ls7 lifters - $121
Interior Whore
- 6380
- fred
- 1996 Camaro z28
max lift on a lt1 is .585 without flycutting the pistons. from what i read on a gm website.Originally posted by DETROITMUSCLE View Postthat cam looks very mild to me, why would you be limited to that lift on stock pistons? You would obviously need new springs so why not upgrade the lifters s well. I'm not quite sure what you mean by your statement Fred.wishing i could drive like joe and the atm squad
Interior Whore
- 6380
- fred
- 1996 Camaro z28
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
So in other words if i get it i will be adding new pistons or fly cutting to my list of things to do for cam install?1999 z28 Bright Blue Metallic 1 of 10
Interior Whore
- 6380
- fred
- 1996 Camaro z28
personally id go with the cc305 with your setup. bigger isnt always better.wishing i could drive like joe and the atm squad
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Purchased the cc305 and a few other things and updated my list1999 z28 Bright Blue Metallic 1 of 10
