again i know nothing about carbs, but i dont understand why the hell you would ever want your secondaries to be vacuum controlled. for any reason at all. and im too lazy to read the article
Kyle, i dont know if 180 is the model number but his heads have 195cc runners.
Most people know this in reguard to CARBURATORS! "bigger isn't always better!"
Several time at work the customer would complain about performance, put on a small carb and the car comes to life!
I am still learning about carburators and tuning myself, so I would call eldbrock, holley, etc and see what they suggest.
I think my Q-jet is 750. I need to rebuild in the next few weeks.
Quadrajunk
94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60'Sold/Stripped 94 Z28 383 LT1 A4SNAPPED CRANK 1992 Camaro RS 305 700r4 Convert. 1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped 1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two "Life is full of decisions, You make them and don't look back"
I posted this on your other BigJon project Thread this morning, but you must not have seen it. Well here it is again. Here is a carb sizing web site you can go to to figure out what size carb you need. http://www.holley.com/applications/C...bSelection.asp
Ive ran mechanical secondaries on the street for years. Heck, fwiw, my wife use to run my valiant on the street when it ran 11s with a chokeless 830 mech. Now I run an 1150 dominator on the street and it idles at lights beter than most peoples 650s. A smaller carb is going to give you quicker low speed response, where as a bigger carb...........properly tuned, will give you ok low speed response, and more high end hp. That motor will run fine on a 650,750,or an 850. Look up the price of a custom built carb.....................than buy seans, lol. And afaik, the only carb made is a holley. Ever hear of a 1000+ cfm elelbrock...........................no, you havent, cause men use holleys, lol. Good luck bro. Eric L
1997 Camaro SS #2819 M6, Red, 3.42, 1 of 27, Ttops, BBK shorty headers, Flowmaster cat back, 1.6 rr, LT4 valve springs, ASAM CAI, Centerforce clutch, runs 12s, breaks 10 bolts. http://s602.photobucket.com/albums/t...20Camaro%20SS/
Vacuum signal Vs. load......Think of a fuel map for an injection set-up. It just makes for a more "smart" carb for a street cruizer. MPG will slightly suffer on a mechanical set-up on the street. Mechanical is the way to go though for all out performance....unless of coarse you get the real deal by going to fuel injection
But If you wanna run it as a street car, and wanna get more then 6mpg and dont wanna have to clear your car out every 10 min cause its loading up to much with gas. Get a 650. A 850 IS WAY to big for a small block, even if its a stroker. And so is a 800, you dont want to have to big of a carb or your just going to be DUMPING fuel in and you going to ruin your motor. (ware out the rings, delute you oil, etc)
I already bought a Demon 750 mechanical secondarys for my 383.
My only concern(after some thought) with Seans carb is it has mechanical secondaries(meaning, when you floor it the secondaries open immediately) they do not open by vacuum.. If it were a 1/4 mile car mechanical makes more sense, but for street purposes and cruising, maybe not so much. I have a 750 w/mechanical secondaries on a BBC years ago and it was too much fuel when I would hit the throttle. Just my $.02 Good luck man!
some one pmed this to me and wanted me to post it in my thread to add to this little war games going on ...
Yes true, Vacuum secondaries are better for street driving. BUT you going to use a pretty decent size cam, and power brakes. The power brake booster uses alot of vacuum, so the vacuum secondaries carbs dont always work that great, along with that big cam not producing alot of vacuum.
This is what scares the hell out of me
Comp Cams 12-254-3 RPM range 2800-7000.
250/256 Duration @ .050 .549/.553 Lift w/ 1.6 rockers, 110 LSA
If this is primarily a street driven car why do you have such a huge cam with those small 180 cc heads ?
That cam isn't likely to make much power below 4000 rpm.
I'll refer to my previous statements on alot of other threads
"Bigger is not always Better, it's just Bigger".
I'm done
Craig
Semi Retired Street Racer
GONE BUT NOT FORGOTEN
sigpic NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
"For you who believe all you read, I caution you - you are daily being brainwashed for profit by extremely effective psychology with very little regard to factual accuracy. In short, you're at the mercy of the world's greatest bullshit artists with the morals of a stray tomcat." - Smokey Yunick
I'm done
Yeah thoes heads are kinda small. Especially for a 383 (imo) But the cam doesnt sound that big too me?
Since its a hydraulic roller right? shoot, Id have a 295 avd duration and like a .580 lift.
Yeah id ditch the torker.
But a Victor jr, For a street car? no. Id get a RPM air gap. I just bought mine last week.
That's 250/256 @ .050 and is huge for a car that is primarily street driven
Craig
