It's been a little while but I don't remember mine having that white piece.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
That looks a lot different from the 94-95 oil level sensors. Are you sure you got the correct one? maybe this is for an LS1.sigpic
I just googled it. Seems to be the correct oneOriginally posted by Plum Nuts View PostThat looks a lot different from the 94-95 oil level sensors. Are you sure you got the correct one? maybe this is for an LS1.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
There are 2 holes above my oil filter on the block. I'm assuming one is for my oil pressure sending unit? What's the other for?
Size doesn't always matter....
2002 Z28 Camaro A4
On 93+ those two holes are blocked off. I know in 93 one is for the oil sending unit like you said, I think the other would still be plugged though...- Brian Meissen
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I have all the stuff to burn PROMs but I have not done one for the LT1
O rly o_0Originally posted by hoogiesngrinderz View PostI have all the stuff to burn PROMs but I have not done one for the LT1
Lol I'd really like to see the process. I just ordered one from pcmforless.2002 Z28 Camaro A4
Got the headers all bolted down. Note: install the oil level sensor BEFORE the lts are installed
<----- this guy learned the hard way. Pulled the drivers lt off, got the sensor in. Double checked that the oil pressure sensor was going to clear, all good there. Tightened down the lt again.
Made sure all my wires were secure and clear of the headers.
Talked to trans guy, he is going to try his best to have it done by Saturday morning.
Stall should be in Friday
Chip is being shipped out Friday.2002 Z28 Camaro A4
That's awesome dude, congrats!!! So happy to hear it's all coming together!- Brian Meissen
