Originally posted by Boost Addict
View Post
Meissen's LT1 Rebuild Thread
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
yeah thats what i meant, crank is turned bearings are fitted to crank.sigpic
Well guys wish us luck! We're going to try to drop the engine today... hope we can get it all out today.- Brian Meissen
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Having yours redone will be almost the same price.
Find out what "NEW" is?
If it's a factory crate motor it might be fine but scamers are out there.
The only thing that it would do is cut your time down.
Order the block, tear yours down and get ready to reassemble.
One thing you might want to replace are the lifters.
All that grime that was in the pan got pass the filter and made it into your motor and that means it made it to your lifters and could compromise the lifters roller bearings.
And you don't turn bearings
You would have to have the mains on the crank turned and use over sized bearings.
And if you are going with a studded bottom end you need to have it lined honed and they will need the studs to do it right.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Yeah I know, what I meant is having crank turned and oversized bearings fitted to crank.sigpic
Originally posted by meissen View PostHey guys - what do you think of this? Do you guys think it'd be cheaper going this route than having my block machined, honed, bearings fixed, crank redone, etc?
http://cgi.ebay.com/ebaymotors/93-94...Q5fAccessories
in one spot he says 3 left down 2 lines he says hurry only 6 left
It's been my experience that it's alot better to deal with someone local...I bought a short block from California and it was junk....and that was from a very well known speed shop. Deal local so if something goes wrong you can go knock on their door.Originally posted by meissen View PostHey guys - what do you think of this? Do you guys think it'd be cheaper going this route than having my block machined, honed, bearings fixed, crank redone, etc?
sigpicTurbo Charged LS1/T56
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Here is the price sheet from the place I use, it will get you an idea.
http://www.pereng.com/Portals/0/price%20sheet%2006.pdf
I couldn't agree more with James on this....when it's something mechanical and of such importance as this, it's always better to deal locally. Alot easier to go work out any problems that may come up when you're standing face to face.Originally posted by WMCCjames View PostIt's been my experience that it's alot better to deal with someone local...I bought a short block from California and it was junk....and that was from a very well known speed shop. Deal local so if something goes wrong you can go knock on their door.
West Michigan Pontiac Club
I agree, use a local shop with a good reputation. You guys live in the "Motor City", there has to be dozens of good engine shops in your area that you can work with.
But until you get the engine out, tear it down and asses the actual damage, everything is just speculation at this point.RIP Doug,You will always be remembered
3/3/53 ~ 12/22/10
1985 Camaro IROC-Z
1974 Camaro Type LT / Z28
2002 Trail Blazer LTZ
1996 Camaro SS (Sold
www.wmcamaro.org
^^^ Agreed.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Alot of guys used to go to Automotive Machine on the corner of Garfield and Utica rds.CraigSemi Retired Street Racer2012 Lava Red Mustang GT 5.0 MT82GONE BUT NOT FORGOTEN
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
- Smokey Yunick
Post Whore-ess
Owns Meissen
- November 13th, 2005
- 9510
- Angie Meissen
- 2002 W68 Firebird, 3800 Series II V6
- Chesterfield, Mi
- Operator/ Receptionist
All day today Brian and Larry have been working and pulled out the engine and from the car. So as of right now John and Craig are also out there helping them out. I will let brian fill you guys in on what happened today. Just a little update.*Angie*
